Hi;
I just changed the oil in my 2002 Toyota Avalon for the first time V-6 (1MZ-FE) engine. The manual says an early first oil change is not needed, but I usually change my oil every 3-4 months so I was only up to 1,500 or so miles.
The results came back with 'Abnormal Silicon' levels, and low viscosity. The suggested limit for silicon was 20, but my oil had 264 ppm.
The engine takes 5W-30 oil, but the 100 degree C cSt viscosity was 8.46. Would I assume that they used a thinner factory fill oil, or that the engine thinned it out in only 1,500 miles?
If it's the former, I wonder if I messed up by changing the oil before 5,000/7,500 miles (the 'normal' and 'severe' service change intervals).
Results were:
Results were:
Thanks;code:
TBN: 3.06 mg KOH/g
Vis @100C: 8.46 cSt
Oxidation: 3 Abs/cm (30 Max. allowed)
Water FTIR: Less than 0.10 %
Nitration: 6 Abs/cm (30 Max.)
Percent Fuel: < 2.0 %
Glycol: < 0.10 %
Iron: 18 ppm
Aluminum: 8
Chromium: 1
Copper: 12
Lead: 6
Tin: 1
Nickel:
Silver: Less than 1
Silicon: 264 (Max. of 20 suggested)
Sodium: 8
Boron: 21
Zinc: 857
Phos: 843
Calcium: 1604
Magnesium: 15
Barium:
Molybdenum: 45
Vanadium: pre>
