It was respectfully directed at the comment about what it says on the bottle vs a manufacturers recommendation and it was not a deflection. There are so many posts embedded within the quotes that I can't tell who wrote what sometimes.
Mobil or Shell (Rotella), there are others as well, have proven their worth in engines by analysis on this forum that we all frequent. Those companies also haven't going through a formal certification process in some instances but print stuff on a bottle. With respect to V-Twin 20w50 it's not even at MA rated. And I bet it is because the high phosphorus content precludes that certification. However it was a really good oil for over 5,000 miles in my ZRX 1200 shared sump. One of the best I've used and tested. Proof is in the pudding, not words on a bottle or lack thereof, IMO.
Those companies are in putting their reputation on the line and would not put a product out there that doesn't protect (which is what oil does) and lo and behold analysis shows the same thing. They aren't risking anything and a motorcycle wouldn't be risking anything either.
However if every spec and detail matches up, absolutely follow it even if there's less options to choose from. That makes folks sleep better with peace of mind and I'm not going to argue with that...
