Originally Posted By: exranger06
Originally Posted By: Clevy
Op.
I will add that a ranger is barely a truck,so keep that in mind when choosing. It's not going to tow or haul much,nor will it get your neighbours out of the ditch,so if all you need is a small utility vehicle I suggest a trailer and pull it with a vehicle you already have,because a rangers bed size and payload is comparable to a medium sized utility trailer which will cost under 1000 new.
Now if you are going to be really pulling and hauling things and actually using the abilities of a truck then buy a real truck.
And the award for most ignorant comment in the thread goes to......this guy ^^. My Ranger can and has hauled over 1300 lbs in the bed on more than one occasion. It also has a tow rating of 5000 lbs. Yep, no real practical use at all...
I also would not hesitate to use it to pull someone out of a ditch. It is every bit a "real truck" as a full size and can do about 85% of what any half ton can do. I have no use for the extra bulk and fuel penalty of a full size, and I will continue to use my "fake truck" for real truck tasks.
You obviously have no personal experience with Rangers.
Fuel penalty? Really dude? Those little trucks get just as bad mpg's as a full size 1/2 ton, ok they might do better by like .5/1 gallon but it really isn't that noticeable, been there done that….
Compact trucks like the ranger are for groceries, odd jobs ( that involve no more than carrying two buckets of paint), groceries, a lawn mower, and what not. Every time I see a compact truck, or even a car for that matter, towing anything it just looks unsafe.
Despite all that I would get the ford, I'm biased, I like ford, besides for those model years of the tundra, it really wasn't that much more truck, at least not compared to the later model tundras.
A 4 cylinder Ranger gets about 28 mpg highway. Let's see a full size come anywhere close to that mileage. You won't get the full 5000 lb towing capacity that the V6 has, but you can still haul over 1000 lbs in the bed. Carrying no more than two buckets of paint? Did you miss the part of me carrying over 1300 lbs of top soil several times? The truck didn't even notice it was back there. Seems all these guys bad mouthing small trucks are just assuming they aren't capable of much and have NO personal experience with them, and are SEVERELY understanding their capabilities.
4 cylinder? Really? Who wants that? Might as well get a Camry, the 6 cylinder is a gas guzzler and you know it, that's why you brought up the 4 cylinder, 1300 pounds of top soil, like I said before your endangering the good people on the road, a properly equipped ranger (2011 model) has a max payload of around 1500 pounds, your not going to tell me that your older one or a 4 cylinder is even close to being rated to safely move 1300 pounds in the back of the bed, are you? Im sure the ranger is a reliable solid truck, not sure what the op wants to do with it as far as work goes, but despite me "bad mouthing" the ranger I would still recommend it over the tundra, but if it where me i would rather have a v6/v8 f150 for work.
