That's why they make BITOGers cry.A lot of the Walmart and auto parts store 0w-20 motor oils such as mobil1 and valvoline have pissant amounts of boron and moly
What about a parody video of all the various BITOGER types?
Statements like these often come from individuals who read the elemental analysis from a basic VOA and believe they have the expertise of an STLE - CLS-certified professional. This is a prime example of the Dunning-Kruger effect in action.A lot of the Walmart and auto parts store 0w-20 motor oils such as mobil1 and valvoline have pissant amounts of boron and moly
I could not agree more with this, it’s the manufacturer defects that usually destroy engines prematurely, not the oil changes/oil/intervals (within reason). As long as that oil level is full and changed within some sort of reasonable interval you should be fine for a long time.I have seen more engines in my life than alot of these oil change specialists. Seen 3k engines sludge up that ran all interstate on Castrol GTX and seen clean engines doing 10k on Synthetic with mixed driving. Sludge should not happen in a modern vehicle that is maintained. If you do nothing for 20k on conventional yes it's going to turn to jelly. Don't run you vehicle with check engine light on as this will affect the balance of what engine needs to run efficiently. The. 3k engine had an EGR problem that customer did want fixed cause it still ran great. Toyota had a problem and so did Dodge with certain engines that sludge no matter what so that was an engine design failure not oil failure. Oil change interval won't fix a manufacturers defect.
I suffer from CRS and skipped the $450 certificate class.Best I can do is a picture:
Please annotate with BITOGers user names. TIA.Best I can do is a picture:
Ya. I'm thinking BS by the author of the post. Too many shops love to play the scare card in order to increase frequency of repeat business.Also Mobil 1 does not turn to sludge unless something else is going on. It's one of the most oxidation resistant oils you can buy. It's always excelled in that area.
Please like and subscribe.Please annotate with BITOGers user names. TIA.
Yeah he’s not a mechanic or anything. Definitely doesn’t know as much as the average BITOGerCCN is using one engine, from one car, driven by one person to make a blanket statement for clicks and then at that did IMO a half ass rebuild. A mechanic only sees the problems.
5K/6m is a very good guideline and then if one chose to, go from there. Personally, 10k is extremely doable on certain vehicles.
I have had friends and family lose engines due to broken timing belts, head gaskets, and catastrophic valvetrain failure. Not once have I seen an engine manufactured in the past 30 years wear out due to faulty oil change practices. It's just not like it used to be. Can it happen? Of course. Is the average person going to wear out a modern engine doing 10k OCI's with the cheapest full synthetic they can get that meets the manufacturer's specifications? Almost certainly not.
He is a YouTuber though so he automatically gets a dunce cap and put in the corner.Yeah he’s not a mechanic or anything. Definitely doesn’t know as much as the average BITOGer
Why? Both make quality oils. Have you learned nothing from this site at all?Mobil1 and valvoline have their fair share of love here. I wouldnt want to put that swill in my motor
SCAMSOIL or nothingWhy? Both make quality oils. Have you learned nothing from this site at all?![]()
The fact that you call it that shows you aren’t learning anything eitherSCAMSOIL or nothing
