Oil pressure dropping a few PSI at idle after 1000 miles on the oil is from the oil viscosity changing from use, not the filter loading up. The PD oil pump is still moving the same volume of oil at idle regardless of the filter loading or oil viscosity changes. And highly doubt the pump is in pressure relief at idle. If the the oil temperature and flow volume is constant, and the oil pressure goes down, then the viscosity had to go down from some shearing.I change mine every 3-4K and have noticed idle oil pressure to drop by 2-3 psi after a few thousand miles, even when using the Genuine Mopar filter.
