energy usage calculation for home cooling
OK Few Of Ya All with Attic - A/C's & Furnaces - need to be Looking at New Roofing Products & Materials
They have Neat Stuff Out Now - Add Nice R value to Outside of Roof sheeting - - as most Roofs get Stripped
To do Roof Correctly anyhow - I'll Try and Find Link . . Search Builder's show in Los Vegas - I believe is where it held ..
First Question should be : Calculated as to How Much Your Foundation is Loosing or Pulling In BTU's of Heat
Either From Hotter Ground Temps around Perimeter or Home ?
To How Much BTU's does Home Loose in Winter Months to Cold Ground around Foundation ?
Calculations say for either Block or Poured Concrete Footer or Full On Basement - then is Basement Finished or Not
Or
Just Freeze Broad Insulation @ R - Rating - Let Us Know - what BTU Leakage is in Either Direction as a Place to Start !
AS IT WILL - SAVE YOU - MONEY
Wait for it ~ BTU's Numbers will be Scary - like - 650,000 - 450,000 BTU's a Week .. 😱
Unless Your in Modern Build with 4~6" Hard Foam Under & Sided Slab or Basement ..
Brand new home, love the idea of foam under a slab. I never saw a production builder to do it in Florida, South Carolina, or our current state North Carolina.
Great idea, though. I think about that even as of this morning, you can feel the warmth of the floor along the outer foundation of the house in the summer and the cold of the floor along the outer foundation of the house in the winter.
I would bet it would help even if you just dug down 2 feet and put Styrofoam at and just below soil level along the slabfoundation.
OK now with that said, we can get really analytical here, during the hot summer months the main part of the house once you’re away from the outside walls cool ground temperatures help keep the house cool and in the winter help keep the house warm. So I’m not sure if you really net losing or gaining anything. Up until this last week the house will stay cool all day long without the unit running and setting the temperature higher for the daytime of course but still in the 70s.
Just a Small Leaky Attic Door is Huge Lost or Gain of BTU's - in - Main Home Easy 100K BTU's
Just Bumped all Attic Doors from R2 to R11 & R12 , so compared to piece Old 1/4" Paneling . .
1 in garage is Right Over Hot Water Tank - I have since Picked Up IR Picturing Device gives 3 Temp Zones
Plus Color Adaption ~ HIGH , LOW , MID - RANGE for Wood , Metal or Electrical -
Now Going on Hunt - Found Ceiling Fans Leaking - even thou - Ceiling was Elect. Box Foamed - Found Missed Points ..
Found some Big Leaks by 3 Gang Boxes ..
Found Attic Doors - needed to be Way Better . .
Found what Looked Like Tight Joints - between 2x12" in Basement were Leaking from Perimeter In.
Found Voids in Walls
Found Wires in Walls so Handy Item ..
After some Good Sealing in all these Places Noted Bill Drop & Dehumidifier is Not Needed as much ..
Picture is showing Pic from IR Screen - of Basement Window in Upper Corner is Coldest in Late Fall- Cold Day
Shooting from My Hand Far Up as able - there is - Old Drop Ceiling type Basement - but at Windows
Large Opening to let Light in - We did R22 in this Area at Freeze Board 1/2" Hard Foam with Spray to seal edges on sides & Top
of Pockets - Not Bottom of Pockets then Backed that R19 .. which is Warm Glow ..
3 Temps are Color Code : Block & Brick have - Metal Steel Support Shelf . that's Coldest .. 54.4F
Now that said I Added Programed Time to Dehumidifier 3 hrs On then 3hrs Off Type Deal
approx 15 hrs Window - then - Off till Next Day .. Lowered Juice Demand - but First Had to Tighten Up Place ..
I only wish I had an infrared imager. I’m crazy about insulation and yes, those attic doors.
I want to insulate my garage since it’s attached to the house. Why rely on the wall insulation of the house between the garage I want to get up there and do the ceiling at the least and the garage door itself. It cooks in there in the summer. It has to be an energy draw on the house even though the walls are insulated with R 15
OK Alarm-Guy - I be Figuring First are You ( Hot Boxing or Vented ) Both work Well in N.C as it's Still Quite Humid
Plus Dry/Wet Cold in Winter . . ( First have to Look at Heat ) & Air - whether you have 1 or 2 systems ..
Slab still be Protected on Perimeter & 2ft , 2.5ft or 3ft Footer - also - May want to Plan on that ..
When & If You Air Gap & Move to Vented Siding ..
One of Big Issues in South is Very Poor Windows - adding Marine Rated Storms in Your Area seeing most in
Southern States do Not ever Open Winds - maybe Once or Twice a Year , so Not Issue & Storms Add Big Air Space that
Keep Entire Window Casing Protected ..
On a Restoration We did I Actually Drilled through Casing on sides & Top ( Steel Header Plate ) Brick Siding
Blew Foam into ( Air Gap Cavity ) - which Actually Leaked Out & Shows how Bad Windows are Installed & many Builders
from 40yrs ago Relied on Caulk - which we all Know - just Does Not Last .. ( Has Not R Value )
I Used Bug Rated Foam - that is - Closed Cell Last Longer . .some of Leaks on 6ft Tall Windows were 1/2" Wide . .
Storms made Huge Difference ( Night & Day ) approx Marine Rated Dual Sealed Harder Temp - Glass $198
If You do this Write Me as there are some " Pro Tricks " that make Job come out so much Better . .
My IR Gun was only $140 off E-bay , and took about 40 Min. to Figure it out & Features ..
I had Prob-table DeWalt Temp - Reader - It will Find Area's - but Not Until You see Picture - Actually Trace to Where
Issues is Coming from ..
I just Read up on Attic Doors which - Equal Hot Issues as many Include Ladders but are NOT Insulated ..&..
May Degrade R30 Attic down to R19 due to Leak Small Door . .
Like in TN most Homes or many in NC Attic Door in garage & Home ..
I Found Adding ( Hybrid Hot Water ) in Garage = Cake Install & saved Big $$$ each Yr. / True Benefit is
Dehumidify Control it Provided Garage - which has No Heat of A/C . .
Oh - Pro Tip - even Younger Guys : If You Attempt Crawling around up in these Small Attics
get some Nice ~ Knew Knee Pads ~ Plus CUT yourself some 36-38" long Pieces of 2 x 6 x 3/4" thk. say 10-12 of those
Push then along Ahead of You - Makes Job Go so Much Better - seeing - We HAD R30 IN PLACE ALREADY so &
took up 3 more Bags.. TO Help with Back Filling on Way Out & Used 12ft Piece of Trim to SWEEP MY WAY
BACK OUT !
I Left Wood in Place Up in there Buried !
Way too soon to know much of anything after one week, but thought I would post this here. First week of June 2026 compared to the first week of June 2025. We are in an extreme drought this June 2026.
I would have to look up temperatures and such but will do more so after a full month. I know this means not that much but interesting for sure.
1. As of right now, the house at 8AM is 71 degrees (night time set back, that I might increase to 72 as the Bedrooms are actually colder) 2. Goes up to 77 degrees (daytime increase)at 8AM
3. At 2pm to 6pm the thermostat goes up to 80, was at 79 and possible it will go back to that, honestly it doesn't get to 80. I just pushed it up a degree to see if it bothered us if it did hit 80 degrees 20 minutes or so before the 6Pm setback, however it hasn't hit 80 at all yet.
4. 6PM when it kicks down to 76
5. 11:15pm kicks down to 71
So far, the HVAC unit has not needed to come on between 8AM and 6PM until evening when the thermostat sets back to 76 degrees followed by 71 degrees at 11:15 PM. (bedtime)
The difference is so dramatic that I would think, by the end of the month, this can't possibly we this good but encouraging to think my theory is working. Even if I cut the HVAC hours by 25% would be substantial, for the first week it has cut HVAC run time by 50%.
I know temps and sunshine matter but we are in a drought this year, last year we weren't and it's extreme. little to no rain for months now in our corner of the state. BTW- we are perfectly comfortable might be a statement for some people that a home temperature kept in the 70's is not hot and I dont see how anyone can't think it is, even if you live in the north. Ps. we never open our windows, keeps the house cleaner, less dust.
Below 2025
2026 (note) we were away for the weekend and the HVAC was set higher during that time.
I'm curious, is the fan left ON during the day? Or is it set to AUTO? I apologize if I missed it somewhere in the thread.
Auto all the time. Reason is unit and ductwork is in the attic. Attic can get to 116f leaving it on would keep pumping warm air in to the house.
During the cooler nights of spring and fall when attic temps can drop into the low 60s or 50s I sometimes put the fan on circulate. Circulate function on Honeywell Thermostats will turn on the fan for short periods of time a couple times an hour. This will bring some of the chilled air down into the house. It also serves to keep the bedrooms an even temperature
FOLLOW UP FROM THE OP POST #1
THE RESULTS ARE IN
Update on the thermostat settings.
Sleep time 11pm to 8am - 72F
Daytime 8am to 2pm - 77F
Daytime (peak usage metering at 21 cents kWh) 2pm to 6pm - 80F
Evening 6pm to 11PM - 76F
Observations -
1. having the thermostat kick down to 72F at sleeping time pre-cools our well insulated house for the entire day with the graduation of thermostat set temperatures. This significantly avoids the peak use time of day at 21cent kWh. Off peak rates are 8cents.
2. What has really surprised me is how much it reduced the run time of the HVAC unit. Keep in mind hours run also matters how long your unit will last, much like the mileage on a vehicle. Running the unit and cooling the house down to 72F during the cooler night time temperatures makes it easy on the unit and stores cool air for the heat of the day.
3. Hard to compare exactly one year over the other year, with variations in cloud cover, temperature difference etc.
THIS IS REALLY VALID for what took place this year. This year our corner of the South East NC has been in an EXTREME DROUGHT. We have had nothing but heat and sunshine for June 2026 compared to June 2025
In fact, just yesterday July 7th for the first time in months we got some significant storms that brought us 1.5 inches of rain. Hardly enough for our approx 20 inch rainfall shortfall. The lakes and ponds in our community are at record lows. Not big lakes but support quite a few alligators. ( I think alligators are cool and cute, sometimes at night residents catch them crossing the road to move to the next pond, which they move around ponds regularly)
Ok, so the results, this is the run time of our HVAC unit comparing June 2025 to our hot and dry June 2026 I m pleasantly surprised by this programing I did for this year. A bit shocked at how much less hours the unit ran this year.
In our hot dry June 2026 this year our HVAC unit actual run time was 20% less then June 2025
@GSCJR
@MountainManDan
Ok, ok, Details - Details (for those, well, you know, like me) *LOL*
Day by day - June 2025 compared to June 2026
Bottom line - HVAC ran 20% less in 2026 and overall the home used 12% less electricity.
WOW! I always check mine but never saw anything like that though I have seen other photos like the same.
I have a lot of grass around the pad, and we have heavy HVAC cooling loads. So the fans are usually running when the grass gets cut. This was after several years of build up. I measured energy consumption the week before and the week after and saw a ~20% drop in electricity use. The air coming from the vents was noticeably colder as well.
