energy usage calculation for home cooling
OK Few Of Ya All with Attic - A/C's & Furnaces - need to be Looking at New Roofing Products & Materials
They have Neat Stuff Out Now - Add Nice R value to Outside of Roof sheeting - - as most Roofs get Stripped
To do Roof Correctly anyhow - I'll Try and Find Link . . Search Builder's show in Los Vegas - I believe is where it held ..
First Question should be : Calculated as to How Much Your Foundation is Loosing or Pulling In BTU's of Heat
Either From Hotter Ground Temps around Perimeter or Home ?
To How Much BTU's does Home Loose in Winter Months to Cold Ground around Foundation ?
Calculations say for either Block or Poured Concrete Footer or Full On Basement - then is Basement Finished or Not
Or
Just Freeze Broad Insulation @ R - Rating - Let Us Know - what BTU Leakage is in Either Direction as a Place to Start !
AS IT WILL - SAVE YOU - MONEY
Wait for it ~ BTU's Numbers will be Scary - like - 650,000 - 450,000 BTU's a Week .. 😱
Unless Your in Modern Build with 4~6" Hard Foam Under & Sided Slab or Basement ..
Brand new home, love the idea of foam under a slab. I never saw a production builder to do it in Florida, South Carolina, or our current state North Carolina.
Great idea, though. I think about that even as of this morning, you can feel the warmth of the floor along the outer foundation of the house in the summer and the cold of the floor along the outer foundation of the house in the winter.
I would bet it would help even if you just dug down 2 feet and put Styrofoam at and just below soil level along the slabfoundation.
OK now with that said, we can get really analytical here, during the hot summer months the main part of the house once you’re away from the outside walls cool ground temperatures help keep the house cool and in the winter help keep the house warm. So I’m not sure if you really net losing or gaining anything. Up until this last week the house will stay cool all day long without the unit running and setting the temperature higher for the daytime of course but still in the 70s.
Just a Small Leaky Attic Door is Huge Lost or Gain of BTU's - in - Main Home Easy 100K BTU's
Just Bumped all Attic Doors from R2 to R11 & R12 , so compared to piece Old 1/4" Paneling . .
1 in garage is Right Over Hot Water Tank - I have since Picked Up IR Picturing Device gives 3 Temp Zones
Plus Color Adaption ~ HIGH , LOW , MID - RANGE for Wood , Metal or Electrical -
Now Going on Hunt - Found Ceiling Fans Leaking - even thou - Ceiling was Elect. Box Foamed - Found Missed Points ..
Found some Big Leaks by 3 Gang Boxes ..
Found Attic Doors - needed to be Way Better . .
Found what Looked Like Tight Joints - between 2x12" in Basement were Leaking from Perimeter In.
Found Voids in Walls
Found Wires in Walls so Handy Item ..
After some Good Sealing in all these Places Noted Bill Drop & Dehumidifier is Not Needed as much ..
Picture is showing Pic from IR Screen - of Basement Window in Upper Corner is Coldest in Late Fall- Cold Day
Shooting from My Hand Far Up as able - there is - Old Drop Ceiling type Basement - but at Windows
Large Opening to let Light in - We did R22 in this Area at Freeze Board 1/2" Hard Foam with Spray to seal edges on sides & Top
of Pockets - Not Bottom of Pockets then Backed that R19 .. which is Warm Glow ..
3 Temps are Color Code : Block & Brick have - Metal Steel Support Shelf . that's Coldest .. 54.4F
Now that said I Added Programed Time to Dehumidifier 3 hrs On then 3hrs Off Type Deal
approx 15 hrs Window - then - Off till Next Day .. Lowered Juice Demand - but First Had to Tighten Up Place ..
I only wish I had an infrared imager. I’m crazy about insulation and yes, those attic doors.
I want to insulate my garage since it’s attached to the house. Why rely on the wall insulation of the house between the garage I want to get up there and do the ceiling at the least and the garage door itself. It cooks in there in the summer. It has to be an energy draw on the house even though the walls are insulated with R 15
