Originally Posted By: Smokescreen
Non-spec.
Upon a search of your particular engine the "worldwide" oil weight applications, many may be surprised at what they find as to what they see here in North America vs elsewhere.
For example, in the North American owners manual for the 10th gen Toyota Corolla 1.8L (which is a world spec engine), there is only 5w20 and 0w20 oils strongly recommended. If one were to look outside this continent you would see this:
"Toyota genuine oil or equivalent
Oil grade - 20w-50 and 15w 40
API grade SL or SM multigrade
10w-30, 5w30, 5w-20 and 0w-20
API grade SL "energy conserving"
SM "energy conserving"
ILSAC multigrade engine oil
As this is for the same world wide engine for this vehicle, the argument for not moving to a different weight (should you choose) is not an issue and certainly not cause an untimely demise to the engine.
I am not advocating the use of heavier weights, just that you research your engine and know more about its design.
This little contradiction is well known and it's good you brought it up. Soon we'll be regaled with the "benefits" of 0W - 0.
Non-spec.
