Originally Posted By: Garak
How would that work? You'll take an awful lot of climate change to obviate multigrade oils. Even an SAE 20 or lighter does no good if it doesn't meet MRV limits for the expected coldest ambient temperatures. And, if the SAE 20 or lighter does meet those limits, it is a multigrade, unless no VIIs are used, and I doubt that oil companies or OEMs are going to be going for oils that technologically advanced for appliances on wheels. Besides, a good VI does help fuel economy testing, and one isn't going to find that in a monograde by its definition.
A monograde up here in the winter would be a disaster, regardless of the SAE number.
I guess that it could depend on how it's marketted in the rules that apply to J300.
Most 10W minerals COULD be sold as a 10W16 under the new J300...yep, multigrade, but still monograde.
Ravenol 0W16 appears to have no VII action, so is likely (or close to) a monograde...and if so, could be sold as a straight 16.
And
https://bobistheoilguy.com/forums/ubbthreads.php/topics/3871970/Is_Fuel_Economy_Hiding_in_J300
I think that there will be changes, and I'm suspecting that they will be along the lines of not having "excessive KV100 for their HTHS"...the Japanese OEMs got stuck with J300 as it was, and created 0W20 unicorn oils to drop the KV40, and reduce shear stability to get where they felt that they wanted to be.
With the new J300 they are less hampered...when they drop KV and go to high shear rate viscosity only, I'm suspecting that VII use at the thin end will drop...last thing one of those oils needs is susceptibility to mechanical shear.
