Originally Posted By: horse123
Originally Posted By: 02s4audi
From everything I've read and I have no proof of this. 0w20 usually is a better quality oil. Made with better base stocks etc. They say that 5w and 0w in normal temperatures are about the same, it's when you get super cold that 0w takes the advantage. I would stick with 0w20. You've been running it no issues and it won't cause any issues... neither would switching to 5w20 or 30 either though
I wouldn't say no issues. I've had twice now in the last year or so where a quart of oil has randomly disappeared from my car in less than a week. I check it on say Sunday and it's just below the full line or at. Then by Thursday the low oil light comes on and somehow a quart has vanished despite no leak and no smokey exhaust. No idea where it's going, but if it's somehow slipping into the cylinders, thicker oil could help prevent that...
I believe your 2012 is the first year of the new (revised) Imprezza with the improved MPG's. I also believe it uses 'low tension' rings in the new engine as a means of achieving this improvement. I also believe there is a class action lawsuit against Subaru for oil usage in their latest vehicles.
If I were out of warranty, I would try 5w20 or even 5w30 to see if it helps with the oil usage.
The thing is I get 0 oil usage up to like 3500 miles in, but the last year this has happened twice where it suddenly used a massive amount of oil in no seconds flat. Then after I refill it, it doesn't use any oil again.
So......What in this odd oil consumption issue leads you to believe that 5W/30 would not disappear, in the same odd way?
The only time I have observed an oil level drop the way you describe is when some contaminant is getting into the oil over a period of time, and is then flared off, by a relatively long high speed run.
Fuel or water. Both get evaporated when you run long and hot enough.
