Originally Posted By: PeterPolyol
Yes PAO usage changes everything, but the principle remains the same. I think it's safe to say that blenders are choosing their base oil profile to meet the W rating they're blending for, and relying on VIIs to fluff kinematic viscosity up to the desired grade.
That's basically the point I was making with respect to blender financials; price point. Two excellent examples are the Castrol Euro sisters, 0w-40 and 5w-40, one blended with PAO, the other not.
Then, we start looking at "expensive" 0w-20's like Mobil 1 Extended Performance versus "cheap" ones that are Group III, and then extending that comparison into the 5w-20 range. There's a lot of variance due to how the different blenders base their products.
Also, we can't forget OEM certifications/approvals here, which test for a lot of things including timing chain wear. Nissan spec'd 0w-40 for the GT-R and I'm sure there was a reason.
If we look at the MB 2012 spec for 229.1/229.3/229.31/229.5/229.51:
http://www.lubritecinc.com/PDF/MB_Spec_EO_Service_Oils_2012.1.pdf
Originally Posted By: Mercedes
M 271 Wear Test (MB DL, Wear, 250 h) c.)
Cam wear inlet / outlet valve (avg. max. wear 8 cams)
Piston ring wear radial @ ring 1 / ring 2 (avg.) e.)
Piston ring wear axial @ ring 1 / groove 1 (avg.) e.)
Ring sticking yes/no
Main Bearing wear (avg.) e.) / (max.)
Conrod Bearing wear (avg.) e.) / (max.)
Timing chain wear (elongation) %
Timing chain wear (single chain link) %
Bore polishing (xmm) - max. value of 6 cylinders %
and then:
OM 646 DE22LA Wear (CEC L-99-08) c.)
Cam wear inlet (avg. max. wear 8 cams)
Cam wear outlet (avg. max. wear 8 cams)
Cylinder wear (avg. 4 cylinder)
Bore polishing (13 mm) - max. value of 4 cyl.%
Piston cleanliness (avg. 4 pistons) merit
Engine sludge avg.merit
Tappet wear inlet (avg. max. wear 8 cams)
Tappet wear outlet (avg. max. wear 8 cams)
Bearing wear main / con rod bearing e.)
Piston ring wear axial @ ring 1 e.)
Piston ring wear axial @ ring 2 e.)
Piston ring wear axial @ ring 3 e.)
Piston ring wear radial @ ring 1 e.)
Piston ring wear radial @ ring 2 e.)
Piston ring wear radial @ ring 3 e.)
Timing chain wear (elongation)%
Oil consumptiong/test
Soot
Viscosity increase at 100°C
So, do we trust posit of base oil viscosity for wear control in the timing chain area, or do we look at spec's with actual engine tests that physically measure it? I know which way I'm leaning... (and this is why I've always been a proponent of the Euro lubes and approvals).
