Originally Posted By: Gary Allan
Quote:
On the back spec'ing. I doubt a car maker would do it.
Why not, is Ford some unique magic entity? They did it with a buttload of units.
Quote:
Well they would have to TEST a used engine to see if it would hold up to the new oil.
I don't think this is the case. They already tested the current engine to the point of failure MANY TIMES. If the current engine and the former engine are technically identical in terms of power density and whatnot in terms of lubrication requirements ..there's nothing to test.
I knew Ford would come into this discussion when I said it. Toyota too back spec'ed but not to the extent Ford did.
I think with Ford, it's more of a calculated risk. They probably don't believe many owners would actually move to 5W20. I think other car makers are not as willing to go out there and say it will work on their older engines without testing.
Since there is NO gain for a car maker to back spec, I really see little or no reason to do so.
Any EPA fines and penalties regarding CAFE have already been paid, so back spec'ing a car will not really help with that.
So what is the upside for any car maker to back spec an older engine that you and I believe would run just fine on 5W20? Make it easier for their dealers? Doubt it.
Yes, I know Ford did it. But I think it was an educated gamble, and not based on much testing.
I think the testing of older engines IS critical for a car maker to do this. If parts wear and an engine is unable to maintain oil pressure using a 5W20 engine after some number of miles, it seems like a mostly down side scenario for the car maker.
I can see it now, someone with 200K miles on their car is told they can use 5W20, and when the dealership installs that oil, the engine begins to knock, etc.
Customer sues, showing all his service receipts that he's been to the dealer for service, and now, after following the new recommendation, his previously problem free engine has become an very expensive and noisy paper weight.
So while Ford did it, I'm not sure what the upside is for them. I think they've largely been lucky.
If I were running the show, regardless of how good I believe 5W20 oils were, I wouldn't just back spec a bunch of 5 or 10 year old engines. Doesn't seem to be any upside for me to do that.
