Dealer using 5W20 in Phoenix AZ!!!!
Arizona
I need advice on whether to continue using my Chrysler dealer. I drive a Chrysler Pacifica with a 3.5 litre HO motor that is clearly labeled on the oil filler cap as 10W-30. The Chrysler dealer here in Phoenix only has bulk 5W-20 and that's it. It's been around 115F for the past month and 5W-20 seems too light of a grade for the car. What do you guys think. I've read a lot on this forum but still unable to decide. I'm a 3k OCI kind of guy. Need advice...Please
New Braunfels
Sounds like your dealer is doing a good job in ordering the right stuff for their line. The 5w20 will do fine, it is not substantially different enough from a 10w30 to worry about. Energy conserving is energy conserving that means a 5w20 is a 5w30 is a 10w30 is a 0w20. The differences between these grades are nominal only.
ON, Canada eh?
It's fine... If you car is speced for a 20wt, it will be just fine. Thicker in high heat is only better in some cases, like racing applications, and even then they sometimes run a very thin oil. Drive happy!
Central Washington
Yes, but his engine specifies a 10W30.
Buckley, Wa.
Dump the dealer....NOW! I can't believe this idiot is not following the manual. I would report him to the corporate big-wigs at Chrysler and go elsewhere for all your vehicle needs. 5w-20 is too light in any weather....per the manufacturer. Geez, it's a shame that he can stay in business with an arrogant mind set like this. Like a freakin dealer can ONLY get 5w-20!! Sorry man...stuff like that just ticks me off.
Thousand Oaks, CA
I wonder if Chrysler has published a service bulletin back specking 5W20 for that engine similar to what Ford did. Anyone know if that is the case?
New Braunfels
Oil pan capacity and predicted oil operation temperature adjustments? I don't know but it makes very little difference. The viscosity rating is at 100c wich is much hotter than even the sump of a street driven car in arizona should reach so the difference between a 5w20 and 10w30 becomes even less significant than the average 2 cst at 100c
M1Ark
Arizona
 Originally Posted By: Tim H.
It is probably ok to run, but I would ask why the dealer is using it, unless your owners manual specifies/allows it's use.
I complained to the service writer who called the Dodge dealer across the street and called a Chrysler dealer in Mesa, AZ. They all claim 5W-20 is all they carry and it's what is required by Chrysler in the Phoenix area. I asked about the 10W-30 on my oil filler cap and he said the extreme heat is why Chrysler is recommending 5W-20. I wrote an email to the service manager to formally complain and met with silence.
Central Washington
Really? With 195F thermostats that are not fully open until around 210F I can't imagine the oil being much cooler than that, espically with longer operating cycles.
Ila Georgia,outside Athens Georgia
Lots of cars/engines that were 10w30 LAST year and the year before etc. are now 5w20 THIS year.Don't make such a big thing over it.If YOU want 10w30 then go buy it yourself.Obvisouly 10w30 is NOT wildly used any more.
CA
Talk about backwards. So since you're in a very hot climate which thins the oil, they recommend a thinner oil to protect from the thinning? I would find another dealer. That's crazy. Maybe in the winter you can run a straight 60wt too.
M1Ark
Arizona
My only concern is most of my driving is 80-85 in 115-117f weather. I guess the thermostat will still keep the oil and coolant at the set temperature.
New Braunfels
True the 3.8 in my jeep was 10w30 for a long time in the minivans and now is 5w20. There is really no difference other than 5w20 is a more up to date spec. I think they are fairly interchangeable but consider 5w20 the better choice. I will and am running 10w30 and 5w30 in the jeep becasue I have it but when that is gone it is back to the 5w20.
CA
Oil is not regulated so it will still run hotter in the hot ambient temps. I lived in Mesa and believe me, my car with an oil temp guage showed the difference in temps. I know you're new to this board but you'll find that there are people that will recommend a 20wt for anything and everything regardless of ambient temps, manufacturer's recommendation, and driving style.
