Impressive work on an impressive car...
https://bringatrailer.com/listing/1947-lincoln-club-coupe-2/Do you have a link for that sale?
Interesting.So close, and yet so far. I wanted to get to the window cylinders to make sure they weren't frozen before trying to raise the windows. Between dad's memory, a not-very-detailed service manual, and some fragmented info on the internet, I got the door panels off. Ford did not make it easy. Have to take the upper window frame out, and they had clever and undocumented ways of hiding fasteners that hold the door panel on. The good news is I can grip the window and lift it by hand, and the window cylinder is moving freely. I hooked up the hydraulic line, reconnected the window switches, reconnected the battery, and... Pump runs, but no movement.I pulled the hydraulic hose off the firewall connection again, verified again it's pumping fluid, but if I put my thumb over the end of the hose, there's no pressure building up. Argh... I don't see fluid gushing out anywhere, so I have a feeling maybe the pressure relief valve is stuck open. It's supposed to open if you run the window up until it stops and return fluid to the reservoir. Since I don't fluid leaking out, and it's obviously not producing the 200 PSI it's supposed to, I have a feeling that's exactly what's happening.
Ah well, guess the pump will be coming out again another day. Enjoying a little single malt Scottish highland goodness right now after a busy weekend.
100% do not ever repaint!!!!!!Thats quite all right.
I would get the mechanicals and brakes sorted, and enjoy it. Wash, clean, polish the exterior as best you can, but I wouldn’t consider new paint.
Many thanks!You are the right man for this job! Nice work.
