Dave Sherman
On to a couple other projects while waiting for the tank to cure. On a whim, I thought I'd revisit the power(less) windows. When I had tried to roll them up to ship it here, all I got was a click. I assumed the window valve solenoids were working but the pump solenoid was not. Turns out the valves at the door cylinders are clicking, but there's also a healthy click from the pump solenoid. This evening's troubleshooting led to a bad find though. I was really hoping it would be something simple, but unfortunately, it appears the pump is seized.
It's got a healthy Optima battery that has plenty of juice to crank the engine, but the battery voltage is drooping to about 4 volts when the solenoid clicks on. No smoke, thankfully, but clearly converting power to heat instead of motion. I did find a spare window pump in dad's supply of spare parts, so fingers crossed that it's still working after living in a box for the last 50 years or so.
Maybe I'll have better luck with the carburetor, got a rebuild kit since it's running lean. Could be a vacuum leak, but figured that carb probably hasn't been serviced in a very long time, and it's probably got lots of gunk in it.
