wemay
Site Donor 2023
EDGE EP 0W-20. It carries a tougher Mercedes approval.
Thank you for a straightforward recommendation. I appreciate it.EDGE EP 0W-20. It carries a tougher Mercedes approval.
No 5w30/0w40 ?I made the switch to Castrol Edge EP 0W-20.
It's very smooth and quiet, extremely yummy motor oil
I guess this thread can be closed now.
Really enjoyed the "yummy" description.......I made the switch to Castrol Edge EP 0W-20.
Why not order it online?Really enjoyed the "yummy" description.......
Actually went out to my 3 nearest sources for oil, Advance, Auto Zone and Wallyworld, only Wally's carried the Edge EP, no stock in 0W-20, just an empty shelf.
Went to Wally's website, the Edge EP was tagged "limited availability" Seriously, I've done enough online buying in the last year to last a lifetime, I really prefer to keep my dollars local. I really doubt I'll ever notice a difference with either the M1 EP or the Edge EP, bought 2 bundles for $38 - $15 rebates, $23 ain't too bad.Why not order it online?
No kidding, **** I asked the same question before I saw this thread. That’s the kind of information needed.Thank you for a straightforward recommendation. I appreciate it.![]()
In a small-displacement DI Turbocharged engine with known OD issues, I'm thinking 4-6k max. I've got 2 of them.I'm sure both are great oils but I would never go 20K on either. I would probably choose the Mobil1 EP based on better cold weather
performance due to PAO....
5K is all I go in the 2.5 Sonata.In a small-displacement DI Turbocharged engine with known OD issues, I'm thinking 4-6k max. I've got 2 of them.
Yep, approvals and specifications are what demonstrate the performance of an oil, not random Internet testimonials.No kidding, **** I asked the same question before I saw this thread. That’s the kind of information needed.
There is not.Is there any benefit in using regular Mobil 1 or regular Castrol Edge (black bottle) over the EP versions if you are changing it at 5K?....I can't see why you would need to.....in fact I'd be fine with Supertech syn. if I was changing it that often....
*Not to get off topic - but I have always wondered if both the M1 & Castrol EP oils sacrifice engine wear additives for longer OCI additives ? In other words , do the Extended Performance oils from both M1 & Castrol sacrifice less engine wear capability for the longer OCI capability ?
