Originally Posted By: DanielinTheLions
The overall picture that I'm getting here though is that it might be better to go with a slightly older caravan 2005-2006 or else go with a rather new one 2010 to present and avoid the 2007 - 2009.
If you are considering the 4th generation (2001-2007), I'd frankly look back to the 2001-2004 vans. You don't get Stow 'N Go with those (that came in 2005), but they seemed to have better reliability earlier on. Seems like parts got cheapened as time went on. The fit-and-finish of our 2007 was measurably worse than our 2003. We have a 2006 at work with similar issues; dash and interior trim doesn't fit right, etc. It's real hard to beat a 2001-2004 Grand Caravan with a 3.3L or 3.8L V-6, but going that far back, maintenance history will obviously play a big part in how reliable the van will be going forward.
If you are considering the 5th generation (2008-current), I'd only look at the 2011-current models. The suspension was revised in 2011, and the interior got a complete (and quality) makeover. All prior engines were also dropped for the very good 3.6L Pentastar engine. It's pretty hard to compare a 2011 with a 2010...the newer ones are THAT much better.
