Originally Posted By: nomochevys
Quote:
And by "abuse" you mean the posibility higher oil temperatures.
Now does that really come as a surprise?
No its not a surprise but it pretty much proves Fords 5w20 spec has been created because of CAFE and the bean counters and not the engineers. Same engine same car and one specs 5w20 and the other that may see high rpm gets 5w50. Ford nor any other manufacture dont always have our best long term interest in mind but you can bet they have theirs in mind from a profit standpoint.
No offense, but you're either being ridiculous or you simply don't understand the function of a cars lubrication system.
ALL oil viscosity choices involve compromise. Yes, that includes European A3 specs and 5W50 spec'd oils. Those oils aren't *better*, they're different, and they come with their own set of compromises. They have increased resistance to flow at colder temperatures, they have higher seal frictional torque and lower efficiency, lower film strength at the top of the piston crown and they generally offer less cooling.
The flip side is that those thicker oils offer higher headroom when dealing with higher oil temperatures and shear rates. Just because a thin oil may not be suitable for extended use at the track, doesn't mean than it can't actually protect better during normal operation. I'm not sure why this is so difficult to understand? Is it that we're just a society that is predicated on the believe that "more is always better, no matter what"?
