I thought there was agreement in 2003 or so these kind of threads would not be allowed on BITOG (?) It's pointless without the specificity necessary (many mentioned already in this very thread).
These oils are so complex that you´d almost have to narrow it down to one category even to have a clue. I just pick the qualities I think are most important for my application and then purchase what I think is best for the money. So for example, I have liked M1 AP 0w20 for my Jeep. I like the combination of high flash point, low pour point, high percentage of PAO, and being on the high end of kinematic viscosity at 212 degrees (8.7) for a 0w20. BUT, I found Shell RGT 0w20 on clearance and with a rebate, combined with rewards at AA, so I got paid 10 bucks for a jug of 0w20, so that´s what is in there right now. I also ran one run of PUP 0w20. I can´t remember why, but the M1 EP, AP, and PUP have all turned in good UOAs. I´m sure RGT will do the same.
Hope that makes sense. You really do have to answer the question for yourself and base it upon what you think are the most important criteria for you. The good news is that with a reputable SAE certified oil that is in spec for your application, you really can´t make a bad decision.
Yes because the truth is the are all so close there really isn't $3 difference in a Jug in my opinion. The only real difference is some Companies bottom line.
Mine had the factory recall. The Pinto fires were blown way out of proportion like the Corvair roll overs.Easy. One of his applications is a 1971 Ford Pinto. The best oil in that case is the one that get you out of the way when someone is barreling down on you from behind.
Motor oils have changed and improved greatly since the early 70’s.
There used to be a sticky at the top of the page addressing "best oil" topics if memory serves.I thought there was agreement in 2003 or so these kind of threads would not be allowed on BITOG (?) It's pointless without the specificity necessary (many mentioned already in this very thread).
Time to lock and send this one into the ether!Old Pinto's gone. No need to continue answering his nonsensical question.
There is no best oil.
What do you guys think and tested as the best brand of full synthetic oil for gasoline engines, or how would you rank them?
Valvoline, pennzoil ultra platinum, mobil one, castrol, supertech, Quaker state, etc
Take a look at actual test results under a variety of conditions then judge for yourself.
