I was wondering if there were any real differences between the bosch premium filters and the supertech filters, the bosch's sell for about $5, is the media better? Both are champion.
Actual evidence of exageration or fraud would certainly be welcome. But lacking such, you presume to spread FUD against Champion Labs through unsubstantiated innuendo.quote:
Originally posted by LT4 Vette:
"How much 'synthetic fibers' added to the ST is probably VERY, VERY little." if any [bold emphasis mine for clarity]"
Wrong..they initially used the media from the Luberfiner High Efficiency elements for Cat, Cummins, and Detroit rather than the "standard" media for those engines.quote:
My SuperTech box says....
"Special synthetic fiber enhanced filter media is superior to leading brands in trapping micron sized contaminants and promoting engine life."
How much 'synthetic fibers' added to the ST is probably VERY, VERY little if any.
I second this opinion and have moved all 3 cars to ST filters because of this. I cut one open and found it to be a very well made filter and the E-Core center was stonger than the alloy metal that others use. For those who doubt the construction quality, I would recommend risking the $2 and open one up. You may just like what you see.quote:
Originally posted by Buick92:
I can see how the cost of a Supertech oil filter can be so low: no advertising, no race cars, no endorsements, etc. I'm starting to wonder if this is really a $4 or $5 filter in disguise.
I for one do not doubt the quality of the filter itself, I doubt its ability to filter, which is what a filter is designed to do. I just emailed champ labs and asked about the micron rating and percent of some of their filters. IF they respond we should have some better evidence that just because the ST box says "synthetic" (so does fram)does not mean its an uber particle sucking machine that will eliminate everything except lepton sized particles from your oil.quote:
Originally posted by jeepman:
I second this opinion and have moved all 3 cars to ST filters because of this. I cut one open and found it to be a very well made filter and the E-Core center was stonger than the alloy metal that others use. For those who doubt the construction quality, I would recommend risking the $2 and open one up. You may just like what you see. [/QB]
No, the Mobil 1 has better media than the ST.quote:
Originally posted by schwartr88:
So the $2 ST is the same as a $12 M1 or other high priced high efficiency filter?
quote:
Originally posted by Ray H:
SuperTechs are the best danged $3.25 oil filters available for $2.07. Conversely, Frams are the best danged 75 cent oil filters available for $3.49!![]()
Thanks for the tidbits of info FG. However, it really does not matter to anyone if there is a better filter that ST, since it doesn't really matter how "well" a filter works. No filter is worth more than $2.07 since an ST is "good enough"quote:
So does the Bosch and STP.
