Analysis: PEA in different cleaners (Techron, Archoil, Oilsyn, Pro-Tec)
GM just partnered with BG, and they're (GM) recommending 44k every 7,500 miles, and every 15,000 miles they're recommending the BG fuel/air induction service which comes in a 3 can pack including 44k.
Of course they are. It’s a revenue stream that will put money into their shareholders’ pockets. I’ll wait until they do double-blind, third party testing that shows the alleged improvements are worth more savings in fuel than the cost of the treatments.
Til then, I’ll use HPL’s Fuel System Cleaner for the pump & injector side of things, and Redline SI-1 for the combustion chamber side of things, and stagger when I use them in order to not cloud the results for either.
I didn't see any HPL fuel system cleaner when I searched? Link?
I use BG44k when I have a chance to get it. It made a noticeable difference in some vehicles that I was using Techron in 2x per year. Never noticed a difference with Techron, thought I was just maintaining clean.
I also use Gumout Multi System tune up and other REGANE ones that have the PEA as recommended here at BITOG. Again no noticeable difference so hoping just maintaining clean, not just cleaning wallet.
Unfortunately it’s a local-only thing; some of the chemicals in it cannot be shipped once it’s all mixed together. I got mine when I stopped by Manteno to pick up my No VII oil. I got a case of it since I’m ~3.5 hours from there and can’t easily get more, either.
Maybe you can get some if there’s a 2024 open house?
Gotta get Dave @High Performance Lubricants to let us know how to get that shipped somehow. From me on Long Island it's 13 hours each way to Manteno. Not that I haven't done strange things like that in the past.
Also, can you get your hands on VW Multi-purpose Additive G001780M3? Its 70-90% PEA according to a 2021 SDS, and is prescribed by VW in a TSB to potentially resolve misfires due to deposits on the fuel injectors and intake valves. They even recommend using it every 5k km if Top Tier gasoline is not available: https://static.nhtsa.gov/odi/tsbs/2020/MC-10176770-0001.pdf
You might use up the whole bottle of Titrant A though ;)
BG actually worked with GM engineers. Their goal is to keep the engine clean, and working longer unlike Chrysler. When Chrysler talked with BG about their products, and they sent them to the marketing team.
I’m not knocking any cleaner just sharing what I know. My engine has seen BG products, and when I pulled the head to replace lifters that collapsed it was surprising clean for a DI engine.
Thanks for the excellent work and sharing with us. Do you have the Gumout Regane line in your market? Curious how it does, as their SDS suggests 10-30% PEA.
https://gumout.com/fuel-additives/regane-complete-fuel-system-cleaner/
Also, have you considered compiling your data and results into Google Sheets or similar? You could record the fuel cleaner, it's model number and the number of drops.
Yes, Regane is available to be delivered from Amazon… But maybe later, it’a pity to pay 56$ for the test) (only pack of 6 is available + delivery cost).
You are right, I’ll compile data to the google sheets, it’s more convenient.
Yes, it’s available. Will add it to the test list. Just ordered couple Liqui Moly cleaners for diesel and gasoline. so please wait, my wife willn’t forgive such expenses))
You are right, the whole bottle of Titrant A has been exhausted, fortunately I have the second:))
NameDropsml in bottleTank (60l) concentration CORRECTION
Oilsyn PEA Doctor90400120
Pro-tec Valves&Injection Cleaner1537518,75
BG 44K 208140325151
Texaco Techron Gasoline System Cleaner100300100
Redline SL-170440102
NameDropsml in bottleTank (60l) concentration CORRECTIONConcentration
BG Performance Restoration PD1540325431:200 concentration
BG 245 premium cleaner62325671:200 concentration
Xado Verylube Super Complex13250101:200 concentration
Pro-Tec CRDSC P210125375311:200 concentration
Archoil AR6400-D Max30400401:200 concentration
Oilsyn Carbone Code Diesel Doctor25400331:200 concentration
Texaco Techron Diesel System Cleaner60300601:200 concentration
Wynn's Diesel System Cleaner W46754832521:60 concentration
Mannol Diesel Ester 99303060ml per 60L61:1000 concentration
Eurol Additive-S Diesel5060ml per 60L101:1000 concentration
High-Gear HG34115060ml per 60L201:500 concentration
Xado Atomex Multi Cleaner025001:200 concentration
Intron dClean D25203045ml per 60L51:1333 concentration
NameDrops
Shell FuelSave 950
Shell 95 V-Power3
Shell 100 V-Power10
OMV 950
OMV MaxxMotion 1002
BP Super 953
BP Ultimate8
Orlen Efecta 954
Orlen Verva 1008
NameDrops
Shell FuelSave Diesel8
Shell V-Power Diesel8
OMV Diesel4
OMV MaxxMotion Diesel5
BP Diesel2
BP Ultimate Diesel2
Orlen Efecta Diesel4
Orlen Verva Diesel4
