Originally Posted By: Gokhan
Originally Posted By: bobbydavro
In reply to Gokhan (having issues with quoting)
Yes there is, the DPF test requires lower SAPS. This is very much part of the specification !
Also can we start talking about VW specs correctly, they don't exist alone and should be paired. 502 is different depending on what it is paired with, 505 or 505 01. Also you cannot claim 502/505 01 and 504/507 on one oil.
504/507 supersedes 502/505 except in markets that deem 502/505necessary, unfortunately it's not that clear due to the global fuel mix but VW are working on resolving this. 504/507 is very much a diesel specification for cars with DPFs and gasoline cars with FSI engines (except in places like china and Russia where 592 is recommended)
Yes, agreed, however, my argument isn't really that VW 504 00 requires low SAPS but it's that VW 502 00 doesn't require high SAPS.
On the contrary, ACEA A3/B3 and A3/B4 do require high SAPS but then VW 502 00 doesn't require ACEA A3/B3 or A3/B4. There are ACEA A3/B3 or A3/B4 oils out there that are also VW 502 00 but satisfying these extended-drain (high-SAPS, high initial TBN) ACEA categories isn't required for VW 502 00.
Wrong 502/505 or 502/505 01 specs have to have ACEA. You can't claim them alone. This is part of the specifications requirement. As said '502' depends which spec it is paired to for the SAP level.
It's no surprise as the head of oil approval at VW is also the ACEA chair
