its funny that Honda is still struggling since the late 90s to make a good transmission without problems while at the same time they make one of the best manuals in the world!My son has an ‘18 civic stick shift - it is an AMAZING vehicle.
Honda has been making great transmissions for quite a while now. Not sure what you are referring to. Every maker has problem children here and there but on the whole they have a good reputation.its funny that Honda is still struggling since the late 90s to make a good transmission without problems while at the same time they make one of the best manuals in the world!
i'm not complaining, I'm stating the facts; it is well documented over the years, starting from'98 thru today, Honda always has had issues with its powertrain, specifically transmissions and moreover in V6 applicationsHonda has been making great transmissions for quite a while now. Not sure what you are referring to. Every maker has problem children here and there but on the whole they have a good reputation.
this is why one sees Toyotas everywhereIndeed. For a while Honda was known for its glass transmissions behind V6 engines. Ridgeline escaped that (but could still lose a trans due to coolant/ATF mixing in the radiator due to a sealing issue). The Ridgeline 6AT is known to have some issues too.
The V6's continue to take a beating, between VCM and still having a timing belt after all these years--while not a "problem" it's still just one more added cost that "many" would take issue with.
Maybe.this is why one sees Toyotas everywhere
I have found an independent car shop that is going to look at the car on Tuesday, meanwhile I commute to work and back home with it
also I gave it a consideration, my next car it will be a sick shift vehicle!
at least, it seems Toyota, their transmissions go on forever!Maybe.
[Full disclosure: Toyota fanboi here, but I’ll be first to admit they have more than a few skeletons in the closet, with 3.blow and 2AZ-FE at the top of the list.]
I got to tell you, I hate this of my, the Apple keyboard!With all due respect, miden851, you already have a “sick shift vehicle!”
They had some issues in the early 2000’s and that reputation has stuck with some consumers. Again on the whole very few have issues.i'm not complaining, I'm stating the facts; it is well documented over the years, starting from'98 thru today, Honda always has had issues with its powertrain, specifically transmissions and moreover in V6 applications
even though it's to the lesser degree in I4, it still happens here and there out of nowhere, such as in my case
Honda Problems
Compare Honda models for complaints, problems & defects. There are 30,332 complaints on file for Honda.www.carcomplaints.com
This sounds like someone is about to fire a very expensive parts cannon...so I took the car to mechanic today and he will be ordering a few parts to the car; he scanned it again for P0741 and drove it; he says this is most likely an electric issue; transmission shifts OK; He said Nissan CVTs when they star to acting up they go into a limping mode, so at least I can drive my Accord
He will go thru baby steps that includes addressing the clutch solenoid first, so that including removing the CVT pan. Once in there, he will replace the CVT main filter. He will remove the valve body and test it, he may order the new one if it needs to be done; Also, he will look at torque converter if there is a need, but he casts a doubt on it since they rarely fail at Honda vehicles
so i'm crossing my fingers here
+1 @miden851Conclusion?
I can’t believe your “mechanic” made you pay the bill for his parts cannon adventure.oh well; i got the car back from the mechanic yesterday, after 6hrs total of his work on it
he changed the valve body control along with its harness, both filters, new fluid; yet, the problem was not fixed
he test drove the car after, and according to him transmission shifts just normal; also, he did not found anything out of ordinary inside the pen
so i spent $1800 for nothing basically yesterday; this brings my total to $2.2K thus far, in the past month
so ill stop it here and wait 'till CVT completely ceases on me, but i doubt it will happen anytime soon
the car just tonight rolled over 69,000 on its odometer
yeah i see your point, but I've needed him than vice versaI can’t believe your “mechanic” made you pay the bill for his parts cannon adventure.
