Exactly.Increased fuel economy (across their fleet)
https://bobistheoilguy.com/forums/threads/5w-30-for-new-honda-3-5l-v6.371338/page-3#post-6559154
You mean Redline SI-1 ? I use it too, good stuff.For the injectors I run Redline SL1 at 60% and 20% olm.
I want to be respectful, but you pulled this short sentence completely out of context. You know you did that, right?
[URL='https://bobistheoilguy.com/forums/goto/post?id=6560213' said:TomYoung[/URL]]
No. Cause comes before effect. Honda quite clearly built a VCM system, without realizing or intending that it would be problematic. Some folks are suggesting that the VCM has narrow passages that the OW20 oil flows through better. I don't know if that is the case, but seems reasonable. What Honda specifies is not relevant.
But, but, but, "I heard...."Positive Displacement Oil Pump ... why oil passage size doesn't matter.
What Honda specifies is not relevant is true in the context of oil specifications that predated the mechanical issue and not action from Honda on oil related to this problem. You took the last line of my post out for commentary, without context. Here you are adding the context back in and saying "see?"“What Honda specifies is not relevant”… in your own words. How is that taken out of context?
“Some folks are suggesting that the VCM has narrow passages,” doesn’t change fluid dynamics. The VCM will work just fine on 5w30, or 0w40, or just about any other viscosity.![]()
and tbnDon't forget HT/HS, PAO, and cleaning![]()
It's all good.What Honda specifies is not relevant is true in the context of oil specifications that predated the mechanical issue and not action from Honda on oil related to this problem. You took the last line of my post out for commentary, without context. Here you are adding the context back in and saying "see?"
This was probably a bad post to get involved with. First, the original poster started with the premise that 0W20 would not work in hot weather. The immediate response should have been that 0W20 works fine in hot weather, but this immediately went to a discussion of the variable cylinder system, with some red herrings like the internally lubricated hydraulic tensioner.
I’m pretty sure 0w-20 is a trigger phrase here. Their safe word is CAFEWhat Honda specifies is not relevant is true in the context of oil specifications that predated the mechanical issue and not action from Honda on oil related to this problem. You took the last line of my post out for commentary, without context. Here you are adding the context back in and saying "see?"
BINGO! That was priceless, TG
We don’t get this new engine in AustraliaCastrol (in Australia) recommends 5W-30 for that engine. They list (4) alternate oils - all 5W-30. Nowhere in their recommendations do they list 0W-20.
Glad you posted that. I have been slapped down a few times for using this trigger word, all the while trying to stay at arm's length from a thick v. thin yipyap.I’m pretty sure 0w-20 is a trigger phrase here. Their safe word is CAFE
Thank you. I think most BITOGers are in agreement with that -- I certainly am. Keep your oil fresh!It's all good.I think we all agree, in terms of long-term reliability, VCM = bad, regardless of viscosity.
But yes, 119* ambient doesn't affect 0W20 any "more" than an Xw50; as long as the needed MOFT is maintained all will be fine.
Depends on the engine oil cooling system (if it has one), and how you're driving in that ambient 119F. So when is 20 not maintaining adequate MOFT? Ans: When it's not, lol ... and nobody has real time MOFT sensors in their bearings to know. A 20 may not maintain adequate MOFT as long as a 30, 40 or 50 in the same use conditions. Would it be safer to run a xW-30 instead of a xW-20 in very hot weather to ensure some MOFT headroom? ... yes it would.But yes, 119* ambient doesn't affect 0W20 any "more" than an Xw50; as long as the needed MOFT is maintained all will be fine.
In my opinion, 5W-30 is what all cars would be speced for if CAFE fines didn't exist.Depends on the engine oil cooling system (if it has one), and how you're driving in that ambient 119F. So when is 20 not maintaining adequate MOFT? Ans: When it's not, lol ... and nobody has real time MOFT sensors in their bearings to know. A 20 may not maintain adequate MOFT as long as a 30, 40 or 50 in the same use conditions. Would it be safer to run a xW-30 instead of a xW-20 in very hot weather to ensure some MOFT headroom? ... yes it would.
Ford also went back to 5W-30 on the Coyote V8 used in their trucks and Mustang.I am glad Ford is specing 5W-30 for all it's Ecoboost engines, so that the viscosity will always be available.
