Thank you, so basically if the consumer does not care about the performance target for fuel economy they can go ahead an run 5W30. So there is nothing to worry about with the AFM regarding grade?
I'm not trying to lead into an AFM discussion, just to verify that the engineers themselves would generally run a higher grade in these engines. Thanks very much.
The recommended oil is 5W-30. I don't under the comment about not caring about fuel economy?
