2022 Chevrolet Silverado 2.7L High-Output Turbo Engine Oil Recommendations
I had googled it with this: What percentage conventional oil does a synthetic blend oil have?
Answer returned by google:
Most blend oils will have a synthetic oil content varying from 10% to as much as 25%. The idea behind the creation of such motor oils is all about offering some of the inherent benefits of synthetic oil, while still sticking to conventional motor oil as the prime component.
Interesting, thanks. I don’t think googles statement is 100% correct though. In the past ive verified with chevron and they confirmed that their chevron supreme 5w30 syn blend contains over 40% synthetic base stock. Pennzoil gold was known to contain over 50% synthetic base stock. Meanwhile, other more bargain-priced syn blends like smittys definitely fell in the 8-20% (depending on grade) range as confirmed by them
If a 5 quart jug of Super Tech Full Synthetic Dexos 1 Gen 3 approved oil can be purchased for $18.64, why would anyone be buying a synthetic blend.
There’s plenty of people that still do- otherwise Walmart wouldn’t have the massive shelf space for it. Personally, I don’t want to switch my high mileage car that’s specd for conventional to syn. It’s ran conventional most of its life and I’d hate to risk leaking through old, hardened seals.
But back to the original topic: Google doesn’t have all the answers
The myth of synthetic oil causing oil seal links was probably due to PAO Group IV based synthetics from prior decades shrinking oil seals.
But ever since Mobil lost the law suit against Castrol that allowed Castrol to call Group III (non PAO) oil "synthetic", synthetic oil no longer causes leaks. 90% of all synthetic oil doesn't have PAO (perhaps just Amsoil, HPL premium plus PCMO, etc, and possibly Redline).
All other synthetic oil is Group III, which won't cause leaks. A group III high mileage full synthetic Dexos 1 Gen 3 oil with generous amounts of phosphorus & zinc anti wear additives, and calcium detergent additive is what I prefer for my own vehicles to help keep the oil seals swelled so leaks don't develop.
The trick is you keep your foot out of it. If a person drives it as if it was a 6.2 the advantage is lost so you might as well buy the 6.2. Take it easy. Reserve the power for passing. :D
6.2L needs 91 octane though, does it not? At a dollar per gallon more...
Then there's the AFM and lifter issues with the 6.2L. And can you get the 6.2L in the Silverado?
Here is a screen shot advertising a 6.2 in a Silverado Bison Edition.
We have four 2024 Chevy Silverado Single Cab Long bed work trucks with the 2.7 in our work fleet as of Feb this year.
They've been great so far .
One co-worker has a 2022 Silverado with the 5.3 as their personal vehicle and they like the 2.7 better.
Funny, my son had a 2.7 in his work truck and he preferred driving my 5.3. To each their own!
Don't call it a myth. Call it the history. In the 80s, filling a high mileage engine that had only lived on conventional, with Mobil 1 for the first time, caused the engine to explode oil from every seam, almost immediately. Been there done that too many times.
The GM 2.7 is one of the most reliable GM engines made today, or in recent times. I was the lead block manufacturing engineer for it.
A high quality 5w30 or 0w40 would be my choice.
I always wanted to speak to an engineer involved in developing an engine. Would it be fair to say that the selection of a rather low viscosity is due to meeting corporate gas mileage requirements rather than letting the engineers write the owners manual and selecting a higher viscosity?
Oil selection is an optimization problem with variables of fuel economy, warranty, durability, operational range, etc. That being said, I always pick the highest viscocity oil spec'd, sometimes one grade higher than spec'd, granted, I live where it's warm (For cars I keep for a long time).
I wonder how I got away with it in my 1974 Buick Regal and my '79, both of which only used conventional until I bought Mobil 1.
I'm still trying to wrap my head around a full size pickup having a 4 banger.... View attachment 249253
Me too. I’m sure it’ll get the job done, but at what cost later on. My son in laws company uses f150s eco boost and tow some pretty heavy job trailers. They either last or end up with thousands of dollars in repairs. My wife and I looked at the new rogues and I walked away from the 1.5. I just couldn’t see it parked in the driveway 100k from now without major repairs. Maybe I’m wrong.
Would you say the others on your team pretty much feel the same way? Who actually makes the recommendation of what oil to use in the owners manual, such as in GM’s requirement for 0w20 in their 5.3 and 6.2 liter V-8’s? I’m interested in how that works. I somehow get the impression the engineers know that a higher grade would be better for the engine but someone higher up the food chain says “ We need to meet the corporate fuel efficiency numbers so go with the 0W20“ . What do you think? Thanks in advance.
GM is a pretty flat company. In the video above Kevin the assistant chief, his boss, and the team make the decision. They have performance targets for fuel economy, power, cost, complexity, operational range. etc. You can add technology, or you can reduce oil viscocity (For free). As long as the engine passes validation with acceptable wear, the oil is good enough. Likewise, the standard oil has to be work in very large temperatue range. If you start your car in a garage, and run at higher temperatures, higher viscocity is a better choice.
The 6.2 runs 0w20 in truck applications. Same engine on the track can run a 15w50.
Thank you, so basically if the consumer does not care about the performance target for fuel economy they can go ahead an run 5W30. So there is nothing to worry about with the AFM regarding grade?
I'm not trying to lead into an AFM discussion, just to verify that the engineers themselves would generally run a higher grade in these engines. Thanks very much.
I am honestly not familiar enough with AFM function and wear conditions to personally comment on how oil viscocity effects wear.
