OVERKILL
$100 Site Donor 2021
But that's the implication, because your UOA has a 405f flashpoint.I did not say 405f when I asked to you imagine 5% fuel. I just asked to imagine if this was 5% fuel. How would it look to you then?
If the viscosity loss was due to fuel; if we were seeing a 350f flashpoint, this would be a different discussion, because it would be one about fuel. But, at present, that's not the case, despite being a DI engine, fuel looks extremely low to non-existent, so the viscosity loss appears to be from the shearing of VII polymers.
To discuss technical things. If you haven't read Doug Hillary's excellent article on the use of UOA's, I highly suggest doing so:I think it does matter, with many complex qualifications, when compared to other UOAs. Why are we even here then?
https://bobistheoilguy.com/used-oil-analysis/
It's a great starting point to understand their usefulness, and limitations.
Yes, the note from the RAT blog was clear that this thread wasn't meant to be overly seriousWhen I posted this UOA, I knew there would be a lot of different opinions and pushback, that is why the first post was somewhat tongue in cheek.
I understand WHY you are doing it (to experiment, which you feel is safe) but many valid points have been raised as to the reason the Euro marques are such sticklers on lubricant performance and why their testing protocols are so exhaustive in nature. The "domestic" (SN GF-5, now SP GF-6) geared oils have always been pretty weak in comparison. Typically lower levels of AW additives, cheaper VII polymers, cheaper base oils, this is because the testing simply isn't as demanding. Most of the Japanese marques don't require anything beyond just API SN or SP at present, but their products are developed, and the intervals dictated, with that in mind.Nobody yet has seen my point in doing so, however. Its pretty plain at this point if you read the thread and all the responses all the way through. I am not playing games, just trying to inspire some thought and conversation.
The Porsche A40 test for example, is far, FAR more than what anything developed for this side of the pond has to go through. That sets the bar extremely high, and typically your BMW LL-01 oils will also have A40 (just as an example) along with the Mercedes and VAG approvals, which all have their own unique requirements. So you end up with a product that has had to pass an incredible amount of testing, which guarantees that the minimum level of performance is set impressively high.
I'm not trying to change your mind, just give you some stuff to think about.
And THAT's the point of this forumMaybe have your wife, significant other, or other non-gearhead read through. They might have a different perspective. This statement applies to everyone here, not singling out Overkill, who is taking the time to help, without snark.
But, let me say this, I take what you all have said seriously, and if this oil has indeed mechanically sheared significantly, I will consider that.
I don't take people's word for it when I hold a differing view. I differ, you differ, so we discuss.
I will take your word for it on which lab to use next time, since I have no opinion of my own.
