Originally Posted By: fdcg27
Why would you even bother trying to replace something as foolproof and easy to use as a drain plug with some sort of valve?
A few reasons:
If you need a new crush washer each time, with Fumoto you can save the cost.
No more worries about cross threading the oil plug, as the valve stays in and never comes out.
No more oil leaks from the drain plug.
No more rubber gloves needed, just flip the valve open.
No more hunting for the right size wrench to fit the oil plug,
Selling your car? Fumoto comes out and drain plug goes back in.
A few reasons:
