Best place to get drain plug washers?
I have a 2012 Honda Civic LX with the R18 engine. My first two times changing oil I reused the crush washer but I noticed a very small leak from the drain plug this last time I changed it.
Where is the best place to get the washers from that is reasonably priced and good quality?
Amazon, Rockauto, 1a Auto, etc?
^ This
Not expensive. You may pay a little more at a dealer but still, better chance of quality control compared to Amazon.
I agree with dealer. But first - what kind does Honda use? Is it a copper crush type? Or the coated ones like Toyota? Or is it just a big flat washer, in which case you don't need a new one likely.
Just go to the dealer. They are cheap. I usually install a new one on every other oil change and never had a drip or a leak issue....
They use simple washer but they're made out of a very soft metal, maybe aluminum. I don't know how people use them more than 2-3 times (I typically do - I flip it over and reuse it once) because they become close to paper thin and can't accomplish much.
There are plenty of knock-offs on Amazon that I wouldn't be afraid of using. What could go wrong ? Worst case, they're a one-time use by being even softer than spec. Honda says to use a new (OEM) washer every time anyway.
I got two sets from ebay, both really cheap.
- Fiber ones for toyota-- I'd torque them but they'd "loosen" after 1000 miles. Fiber seems to compress over time. Not good.
-- Aluminum ones, generically sized. Work great. Think I paid $4 for 50 of them.
