Originally Posted By: Garak
Originally Posted By: Tornado Red
In Saskatchewan, there should be at least four or five other readily-available oils that will work just as well. From Esso, PetroCan, Shell, for starters. UFA used to sell a good full-synthetic diesel-rated oil under their own label. And there must be others.
Looking at VW's list, about the only one readily available in Saskatchewan would be Castrol Edge. Certainly, there are others that would probably work. However, if one wanted an approved lubricant, that would be about it. Of course, the dealer is always an [expensive] option.
The question was about the BEW engine, aka the PD 100 engine found in the 2004-2005 Jettas, Golfs and New Beetles, I believe. As these vehicles are now out of warranty, it is not necessary to use a VAG 505.01-rated oil. There are many API-rated 5w40 oils, and a few 0w40 ones, that will work as well or even better; and they are relatively easy to find.
In the US, many owners of Volkswagens with this particular TDI engine are using Mobil 1 5w40 or Shell Rotella T6 5w40, with excellent results. Canadians have different choices but not fewer though.
