Originally Posted By: Pesca
Let us put the warranty problem aside for the moment.
From what I understand, VW507 oil is required mainly for extended drain intervals.
Does that mean you can use any synthetic oil (PP, Syn, M1 (not the ESP version),...) which are not VW507 certified in a VW507 oil required engine, as long as it is not for extended drains (between 5 to 8 Kmiles)?
Are there any other problems you can have by not using the correct oil, even on shorter OCIs?
To be more precised, I am talking about 5W30 version of these oils.
Thanks in advance,
I just call the VW dealership in Chattanoog tn, the service mgr says to use the 507 oil in the diesels and nothing else because special additives in European oil. He said do not buy the autozone or off the shelf oils because at about 200k miles ur bearings start to go out and on some older model diesels the oil pump system goes out. So I would go with what he said,,do not use Mobil 1 or anyother synthetic he said.
Thanks in advance,
