I searched and found some info here on zinc in motor oils,I have an experience to share,I'm a new guy so bear with me
I have an old Chevy truck powered by a heavily modified 1950's 302 GMC 6.The performance cam lost a few lobes after about 1000 miles.I tore into the engine,yup,2 lobes galled badly.
Talking to several aftermarket cam grinders and engine builders,they all pointed to the lowered zinc levels in oil.They all had the same story,flat tappet cams,mostly used in older OHV American engines suddenly had problems,where they had none before the zinc reduction.We're talkin performance cams and stronger valve springs.
All the people I spoke to suggested using a pint of GM assembly lube poured directly into the crankcase along with brand name Diesel 15-40 oil for initial cam start up and then either 15-40 Diesel or Valvoline ZR conventional racing oil,the Valvoline appears to have more zinc than most any other oil.
I've read,that during the first 5 minutes of life,a flat tappet cam and lifter may have as little as .003 inch contact surface.With all the spring pressure pushing down on that dot,maxiumum protection is needed.
So,I have bottle of GM lube,Diesel and Valvoline oil,not gonna repeat the bad cam problem........
