Hi everyone,
First time posting and just looking for your expert advice regarding choice of oils for engine run-in. I appreciate this topic will have been done to death so apologies, however the answers I'm looking for seem to come from a range of sources, many of which seem to contradict each other.
I'm from the UK and am restoring a Triumph Herald, the engine is identical to that of a Triumph Spitfire. 1300cc straight 4, flat tappet cam with solid lifters. I am having the engine fully rebuilt by a shop I've used previously which has been rebuilding classic engines for decades so I am very confident with their care and attention to detail in building it. I don't want to mess anything up during the vital running in phase.
It's universally agreed that the very first start should consist of breaking in the camshaft using a very high ZDDP break-in oil (I'll be using Ravenol 20w50 mineral break-in oil that has a ZDDP concentration of 2500ppm). I will prime the oil system using a drill attachment to the oil pump, ensure everything is set up for a quick start, and upon starting immediately bring the revs to between 2000-2500rpm for 20 minutes, varying the speed between those 2 values as you go. Change the oil and filter once complete.
Okay, so this is the bit where I get a little confused. The next most important/tricky component to break in properly is the new piston rings to the newly honed cylinder walls. Again, it’s universally agreed that for the first few hundred miles, idling the engine and running it with no load should be kept to a minimum. I have read from numerous sources that a super high ZDDP concentration while essential for camshaft break-in, can actually hinder the correct wearing in of the rings by promoting glazing of the bores and is considered a necessary evil while during the first run as the camshaft takes priority.
What I'm wondering is once the 20 mins of camshaft break-in is complete, am I okay to replace the Ravenol oil with Valvoline VR1 20w50 (I’ll be using this after it’s fully run-in too) that has a ZDDP concentration of 1300-1500ppm, or will the camshaft require further breaking-in with the super high zinc Ravenol oil for a while? Also is the ZDDP content of the Valvoline adequate enough for breaking in the piston rings during those first few hundred miles?
As I understand it, the rotating components such as the crankshaft and big end bearings etc are of least concern, as long as there is good oil pressure and you don't exceed say, 4000-5000rpm during the first few hundred miles then they will wear in just fine. I believe this is right but please correct me if I'm wrong.
Finally, are there any more tips on how to drive initially for the best results in breaking in piston rings?
Many thanks
Peter
Many thanks
Peter
