- Joined
- Dec 21, 2024
- Messages
- 5
Howdy people. This past spring I built a 1977 Ford 400 and installed Comp Cams 268H camshaft in it. I want to run a 5w-40 oil in it so it'll lubricate better on cold starts but also has characteristics of a 40 weight oil at operating temperature. There are no oils thinner than 10W-30 that are advertised as containing "high zinc" so I have to look into Diesel oils. Since I work at a Ford dealership and I get discounts and have access to Motorcraft parts and oils Im curious about the Motorcraft diesel oils. Does Motorcraft's Diesel 5W-40 Full Synthetic oil have enough zinc for flat tappet cams or will the detergents be too much for the zinc to perform? FYI, I'm specifically asking about this oil, not Rotella or any other diesel oils.
