Turn them inside out and get another day or two.I have reused filters twice on cars and motorcycles several times w/o any problems. Only thing I absolutely use only once before changing are;
The efficiency looks to be around 99% @ 200 microns. What is the efficiency rating?I use OBERG oil filters on a couple of my engines. And generally always use them for anything that is a "built" engine. These filters are servable by cleaning them. The servicing is a little more involved when changing the sump oil taking the oil filter service from a nice 30 minutes to about an hour. What is my point... well simple not many on this forum take apart their oil filters and look at the filtering elements each time they change an oil filter but I guarantee if you saw what gest caught and filtered out of the oil even on 3-5k mile service many of you would stop the poor habit of not changing the oil filter each time you do a sump fluid change!
This is my BABY Oberg. The other are twice this size. Oh and MOPAR use to offer them as kit in MOPAR Performance Parts.
No Thanks. I actually had to do that for a week or so during the Gulf War. I change them q.dTurn them inside out and get another day or two.
couldn't tell'ya without looking it up. They are still widely used in performance and many BOAT and Airplane applications.The efficiency looks to be around 99% @ 200 microns. What is the efficiency rating?
ZeeOSix,You should read this thread startng from the linked post. Oil filters can become less efficienct as they load up, and it starts way before the filter is totally loaded and close to bypass delta-p.
https://bobistheoilguy.com/forums/t...e-point-and-burst.334882/page-19#post-5789087
Good idea. Why fix something if it isn't broke?Let's say you have a premium oil filter and like running 5,000 mile oil changes. Would you ever run a filter thru say 3-4 oil changes?
If you have run the filter thru 2 or more changes, do you dump the old oil out or just leave it in the filter/cannister?
I am debating running my Fram Ultra thru 2 changes. I have never done that before.
Never buy a Honda and follow their maintenance schedule.It's always fun listening to people come up with excuses to do something half assed. Now I know why my parents smiled and laughed so much when I was a child.
Must be those lazy engineers again.![]()
Oil filters change interval isn't driven by CAFE ...Yeah, the same one's who "recommend" 0W-16 oil in Toyota's.
Honda's recommendation of changing filters less often than oil is more about saving money for dealers and customers. Many customers will not follow a maintenance schedule that calls for frequent fluid and filter changes at their expense. All the automakers know this and have made adjustments.
That's why you see "lifetime fill" on automatic transmissions that used to have 30,000–mile ATF and filter service intervals. The car will last through the warranty period on the cheaper maintenance schedule, but after that...
My suspicion is that the the life of automatic transmissions in most vehicles has actually declined in recent years because of "lifetime ATF" replacing fluid changes. Salvage yards will tell you more vehicles are junked for trans failures than for engine failures.
Cutting back engine oil filter changes is more of the same warped "logic". The really bright side for the automakers is increased sales of expensive reman engines.
