Scott S
Thread starter
What would you get 49%?Try those Boveda packs for a while. They come in larger sizes as well. Don’t be afraid to use several at a time in differnt spots.
Once you begin to raise the humidity levels, leave the safe closed as much as possible and use the bluetooth to monitor.Very dry heat..
Yes, sir.What would you get 49%?
Have you ever used them in a gun safe or you never had to?Yes, sir.
I did indeed when I first got mine.Have you ever used them in a gun safe or you never had to?
Thank you it's accurate I guess?I use the Govee brand.
I never checked it against a calibrated unit but if you look at that pic of my app, you’ll see I also use one in my acoustic guitar case. I checked them against each other and they were within .2 of each other.Thank you it's accurate I guess?
H5075Which one did you get, I see several different units?
I meant the cloth bags. I bought a starter pack for now.By separate, do you mean individual packs? No, Amazon sells them (49% packs) in quantities of 4, 12 and 20 from what I just researched. I had bought a 12 pack since I use two at a time for my guitar case.
