Can you turn it into a grommet? Make a hole for the cord?It's a little rubber plug..
https://duckduckgo.com/?t=ffab&q=grommet&iax=images&ia=images
I would have to look after I pull the safe away from the wall, what did you do with yours just stuck to cord through and that was it?Can you turn it into a grommet? Make a hole for the cord?
It's been awhile.I would have to look after I pull the safe away from the wall, what did you do with yours just stuck to cord through and that was it?
No worries. You want the RH in your safe lower than the room as we all do.Thank you for all your help looking for something. I really appreciate it.
Under 30% RH? That's DRY! Not good for humans!!Right now it's staying right under 30, I know typically between 50 and 60% is good.
Yes I realize that it's got to be raised..Under 30% RH? That's DRY! Not good for humans!!
I question your gauge. What are you using?Yes I realize that it's got to be raised..
How long has your safe been in the house? The drywall is probably still sucking in water vaporI just put a dial gauge in there, that I checked the digital one against before, and they both ran about the same.. but this is what it's reading right now..
Wow! You’re in Dover?About a year
Man your place is the Sahara!About a year
