Hood pin or hood latch for a compact car?
Silicon Valley
Previously I got into an accident that the hood is bent. After I tore out the bumper and try to pull the radiator support back, I found out that "somethings" are bent left and right to compensate for the radiator support pushed inward by about 1/2 to 3/4 inch. I look at the body line of the front fenders and see that they are bulging slightly over the highest point of the wheel wells. Anyways, the conclusion is either I have to go the traditional way to PULL something back in place, or I have to find a way to bolt the hood down to compensate for the hood hook and latch being off by 1/2 to 3/4 inch.
I helped my dad arranging a similar repair last year on a Mazda 5 and the pulling + head light is about $2300 total. If I have no headlight damage the repair would probably be about $1800 if done correctly. This car is worth $1350-2000 depending on whether it fail smog or if the owner is in poverty, so not really a point in doing a good frame pull. At this point I think a new (used) hood also no longer makes sense, and having a dent hood with hood pin or latch seem to be the most economical and reasonable solution. Now the question is:
1) Is it dangerous to use hood pin if you hit a pedestrian (just in case) at lowish speed? I don't expect to hit a pedestrian above 30 mph but never say never. There are some hood pins that stick out an inch or so, from say Summit Racing. Is it safe or should they be only used on track cars.
2) Security. I know that people can always slim jim a car then unhook the hood cable, but knowing someone have an unlocked hood latch or pin system is going to eventually get battery stolen. I just bought a new battery last month so it is not like I have a 4 year old battery nobody will steel. Any recommendation for which lock system to use? In the worst case I guess I can install even a pretentious lock that is not connecting to anything as deterrence and use a non locking sturdy one for load bearing.
3) Would it be easier to install hood pins or hood latch? I have a relatively curvy hood so I am worried about pin not able to sit flush for the locking system. Will a Jeep hood latch be able to fit any other curvy car if I don't mind drilling holes on the exterior? (assuming I don't care about look).
4) Any recommendation on aftermarket hood loop / hook hitch system that has adjustable positioning?
5) How strong do these system have to be to hold down a normal passenger car hood at 85-90 mph? I don't typically go above 80 but safety margin is nice.
Hood pins with little padlocks?
Might even have a random bitog’er take a photo and post it on the unusual vehicles thread. /jk
How is the hood latch installed? Can you unbolt it, bend, drill and bolt a piece flat bar to the original mounting holes, and then install the hood latch to the flat bar in a position that will line up?
I would see if I could get the factory hood latch to work. A bit of hammering, pulling, to move the latch to the match hood loop. Loosen the hood hinge bolts and slide any play, or even ovalize them a bit more to move the hood back?. Maybe move the hood loop?
Just keeping it looking stock, if a bit bent up is good just in case you did hit a person too.
Having pins seems like a bad idea if you park where people mess with cars.
I would not stress over pedestrian safety too much. Is there a tree you can chain the rad support to and just back up at increasing speeds til it’s back in place?
Hood latches are TOUGH if the hood latches. I wouldn’t be worried about the hood opening if the latch actually latches. I’ve seen the metal U pull out of the hood before the latch lets go.
I think it is spot welded on a specific spot. You can't bend it 1/2 inch away.
It is mounted flat on a L shape bracket that is part of the T structure of the radiator support. I tried pulling it forward but the top of the T is actually pretty stiff. I can literally lift the car up by jacking that top part (and I did earlier) and it still didn't "bend" or "pull". I guess that's structural integrity?
No tree nearby to pull without getting into trouble. They are either too thin or too big to catch the wrong kind of attention (we have one right in front of the city hall and police station). Glad to hear hood latches are tough.
I "think" this should have enough safety margin on a passenger car hood?
