Winchester TS26 Gun safe installing Goldenrod
Myrtle Beach, SC
I have the above mention safe, I am looking to install a golden rod in it, the back of it is not pre-drilled, what is the best way to do this and seal it back up again? Also what size drill bit would you recommend?
Thank you
I used 3M windshield rope caulk on something similar. Never hardens, non-corrosive, safe on metals and painted surfaces, not as messy as tube caulks/rtv and very easy to work with. Downside is it stays a bit tacky.
I have a plug in the back, but I have to drill through the sheetrock and carpet. And then for the little cork around the hole in the back. So I guess either one of them I can use?
