You are fundamentally and fatally flawed in your understanding
Good thing he's being helped around here. It's up to him to grasp it.
Kamele0N said:... cars of that era never made it to 100.000kms anyway (due to inferior metalurgy of that time)
Their engines got rebuilt before no matter what oil was in there
In a reciprocating engine, dead centre is the position of a piston in which it is either farthest from, or nearest to, the crankshaft.Near the end "the piston stops moving for a brief moment". No, not really, and,,,,,,,,, yes, the moving piston can always be in a "stopped" state, just take delta-t to zero and voila, piston is stopped even though it's still moving.
Yes, but velocity = 0 does not mean the body is not in motion. To observe motion (or no motion) you need non-zero dt.In a reciprocating engine, dead centre is the position of a piston in which it is either farthest from, or nearest to, the crankshaft.
Its velocity at either point is zero.
If the crank is moving the pistons too are ALWAYS moving.
Who's the engineer?You realise he's an engineer? he's putting it in layman's terms.
You cannot have the piston change direction by 180 degrees, and not have it "stop" during that process.
The crank is moving rotationally, connecting to something 'hinged' on the piston. It's translating rotational movement to reciprocal movement.
I think folks are referring to the angular dwell time where the piston is in vicinity of a dx for some time dt, which is related to the freq of COS function.
Remember, if you say "for a brief nano-sec", those words mean dt > 0
It never stops moving.
You need to learn some things. It's not just pistons, it's a lot of other things as well.It never stops moving, not even for a brief 1/1000^100000 sec.
Show me. I am open to learning.You need to learn some things.
..... goof post, cant delete
zero is the speed, the scalar of the velocity vector.So, you're saying that you cannot be at zero, to change direction?
You must know of the maths/physics example/joke of the fly hitting the freight train head on?
Like the speed of a tire at the contact point.How in the world can something change direction 180° but not stop at one point. Makes no sense. The crankshaft is always moving yes but it is not changing direction and is connected to the piston with two separate pivot points.
?Show me. I am open to learning.
What's the speed of a tire at the contact point?
Then how does the piston reach a maximum velocity?Define "stopped" mathematically, then I can continue to explain.
The crank is ALWAYS changing direction, if it wasn't then the piston would not go up and down.
It reaches max speed (a scalar component of the velocity vector) in one direction when the crank arm is exactly 90deg from line of linear motion.Then how does the piston reach a maximum velocity?
