Why isn't High Mileage oil the "standard" oil?
I do not agree with those statements - additive suppliers do sell "boosters" to blenders for HM products. Whether or not they are needed, is up to the individual customer.
https://www.aftonchemical.com/resou.../gf7-update/go-beyond-performance-with-afton/
All I see is more marketing blah blah.. the "boosters" they are talking about are most likely added group 5 base oil since it is great at cleaning deposits, swelling seals, lubricity, film strength etc.
Yes, group 5 oils have several benefits other than the seal swelling. Basically any full synthetic will have some group 5 but the amounts vary
That's inaccurate. Some use little to any ester content, instead opting for Group I or II for solvency. AN's are a very recent addition to engine oils (outside Mobil), replacing esters in some recent Mobil products, but we've also seen examples of neither being used (current M1 FS 0W-40 for example).
Here's a PAO + Group II+ Mobil blending guide example:
Yes anything that says synthetic or synthetic blend means it has at least some group 4 PAO, and likey a bit of 5 to help counter the 4 but not always.
No, most synthetics have no PAO in them at this point in the game, using Group III instead, due to cost.
Yes. To what extent depends on the amount of PAO and esters used in the blend. The group 5 base oils are the main contributor to the seal swelling of HM oils. Group 5 is also great for cleaning engines.
Not all esters are cleaners, so just because an oil has some ester content does not mean it's a good cleaner.
Yes, based on what I've read here, I didn't think sys must have PAO or Grp 5. I had also read many posts that some syn had PAO but now they don't. iirc, one of M1 oils (Euro 5W-40?) dropped PAO from SN to SP or Castrol Euro 5W-40 with bunch of Euro approvals (like M1 Euro) has no PAO or something to that effect.
Anyways, I don't pay much attention to the base oils since I chase approvals if any but syn must have PAO raised the red flag.
I have posted this before, but my work vehicles (Fleet) always got Valvoline Max-Life synthetic blend High Mileage oil every 5K. From brand new, up to 100K when we would get a different vehicle. Only car that ever blew the engine was the Ford Fusion, but it had nothing to do with the oil used.
HM from day 1 isn't an issue. Now, is it beneficial? No idea. I certainly wouldn't pay extra for it.
Group 3 is not a true synthetic base oil, it is mineral based. However, companies are legally allowed to market synthetics containing group 3 as "fully synthetic" because they are now refined enough to have similar viscosity index properties as a real synthetic group4/5. It is deceptive marketing at best and really just false advertising.
It's synthesized, so why isn't synthetic?
"Legally allowed". Was this part of the Castrol court decision?
In invite you to re-read what you wrote:
Since the conversation about an oil being labelled as synthetic vs what it's blended with is wholly separate from your statement.
We're all aware that using High Mileage in a brand-new engine from day one won't cause any issues. So my question is, besides from oil companies wanting to line the shelves with more product, why isn't  all oil the "high mileage" formulation with additional seal conditioners to simplify product offerings?
In other words, imagine that vanilla Mobil 1 jugs of tomorrow just contained what Mobil 1 High Mileage is today, and then the "Mobil 1 High Mileage" name went away.
Would there be any drawbacks? Is there a compromise made with HM oils to emphasize seal conditioning at the slight expense of something else?
Reading this entire Q&A on synthetics I think knowing which synthetic type or grade can actually help in your type of need. Full synthetic or synthetic blend marketing sounds like I cannot afford full synthetic but I can afford some synthetic mixed in conventional oils. Depending on what your after out of your engine most people don't keep vehicles till 300K miles so oil life & frequency is important. Performance oils create less friction quicker to max RPM longer stability in viscosity in extreme conditions. Name brands are always better than off brands, Store name brands I.E. Generic. I've always been a fan of Castrol, our grocery getter Honda was nearing its end with us only because of comfort. I had planned on 1000 mile trip and needing oil changed I used Walmarts syntec brand. After the trip the valves(OHC solid) were rattling. Only 80K miles my valves shouldn't need adjusting? I had the same trip again changed the oil again but with Castrol after the trip no valve clatter. Walmart syntec brand is crap to say the least. My point is driving conditions and how long your keeping the vehicle should be a factor in what oils you use. Putting $50-$60 a jug synthetic in a short lease car is a choice not a need to.
“Walmart syntec brand is crap” you day? What is that exactly?
I’m a little confused as to how the base oil composition causes valve rattling. What do you think caused that?
