Originally Posted By: Capa
Purelux, the people that are saying that you don't need gas or oil additives are saying this BECAUSE all gas and oil already has additives.
Since I use synthetic oil, I personally wouldn't put another additive in the oil. However, even though I do use top tier gas, I go ahead and add an additive to the fuel once or twice a year though I will admit I haven't seen an increase in MPG when I have done this.
Very little additive in even top tier gas. Maybe enough to offset fuel contamination, but nothing to lube the upper cylinder. This is useful to offset the ethanol content. Some use MMO for this, others Lucas. I like tc-w3.
Edit: you may have a point about oil, though taken to its logical conclusion, one would wonder why there are the differences there are among oils that have the same grade and API certification. As all oils have additives, and they are all sufficient, why then are the additive packages so different.
-Spyder
-Spyder
