mikeduf
I must admit that was a very interesting article about early oci. I can see there is a lot of analysis done on the different mileages on the engines for the OC.Wear rates are highest at the front end of an OCI. The longer the lube is used, the lower the wear rates become (irrespective of brand/grade; with limitations).
Well documented and discussed here:
https://bobistheoilguy.com/used-oil-analysis-how-to-decide-what-is-normal/
And logically that would make total sense as fresh oil will strip out the good oils that have coated the internals just to start over again. ( layman's term)
Well I am by no means fanatical about changing my oil at 1K it's just been a strange habit that I picked up last year. I will be pushing out my oci to at least 3 to 5K. Thanks for the article
