I was going to say the same thing. I've always had more pronounced results from fuel system cleaners when driving for long periods. I've always felt that the cleaner works best at operating temps and a steady state of rpm (like highway driving). There may be a similar affect when the cleaner/fuel mix is simply sitting in the system cold and not flowing when the car is not running, but I'm not sure.Going back to my early days of driving till now, If I have a trip, I always keep the old oil in and change it on my return as trips are EZ on oil.
I would check the level and perhaps use this trip to add a bottle of a good POE fuel injector cleaner as I also prefer to use those gas additive cleaners BEFOR I do a fresh oil change. My 2 cents...
Either way, it makes the most sense to do it right before the oil change and not after. Any contaminates remaining from the fuel system cleaner will be removed in the fresh oil change.
