Why the huge obsession with adding MMO?
Originally Posted By: Lethal1ty17
Originally Posted By: FZ1
Look,boys. You don't stick foreign objects in your eye,do you? So don't stick foreign objects in your engine. Really,how hard is that?
eyedrops? contacts?
What about drinking vodka through my eyeball? Read that on the news.... Too much makes you blind.
Originally Posted By: Gary Allan
Well, I surely give high marks for butt dyno quotients. It's one of my principle criteria for proving worth of any product.
Measurable, repeatable, and validated results are highly over rated.
Think about it, if there were some testing that could be performed, don't you think that Turtle Wax would perform them? It's surely not for lack of resources.
They don't even have the 4 ball test
I don't see how dyno results would show the benefits of MMO. Professional racers use their engines for only a season or a race, so any type of additive or motor oil formula that gives better dyno results would be useless for consumers who want to run their car for 10 to 20 years.
However, due to the decreased viscosity, I'll bet you'll bet better dyno results.
Quote:
Right, but my point is that the results people see from MMO are hard to quantify. Its like the improvements I saw after using Regane - I can't measure them, I just know it worked. This was the first time any PEA based cleaner was used on this car though, so any of them would have produced similar results. Regane just happened to be the easiest to obtain here.
Sure. I'm just being difficult (it can be a meat grinder in here)
I really don't have anything against the stuff ..especially in fuel.
Unlike oil, fuel ..hmmm..how can I word this without stepping on myself???
Even top tier fuel can manage a few liabilities to it in some instances. Fuel is a "globally managed" commodity, by that I mean mostly generic with some minor distinctions in end vendor additives.
So, there's work to be done for the end user in some cases, your reference to REGANE containing PEA, being a good example. You probably won't see any more MPG with using PEA, but drivability and reduction in knocking ..starting issues ..misdiagnosed piston slap due to CCDI ...etc..etc.
I guess I'd say that there's a sizable minority that can gain benefit from using such agents.
Oil is a different animal ..for me anyway. When stuff like Rislone and MMO started out, the consumer (before the term existed) had choices that were probably ND SAE 20 and ND 30. Even through the 70's the fundamentals of lubricating oils were pretty primitive. Stone knives and bear skins.
Now I can choose from a very broad selection of high quality oils from multiple producers that are so far ahead of typical needs curve it's not even funny.
There will always be exceptions. If you've got some exceptional circumstance, then you take exceptional measures.
What people need to NOT turn that around into ..is that they're getting added benefit when there's no need to begin with.
You can't get above ZERO ..which is where you start (and typically stay ..within some standard deviation), you can only combat negatives.
Well stated. You hit the nail head on with my Regane usage: while some might not see any benefit from it (and few the same benefits I saw), in my case there was a definite need for the application of a product like Regane. It delivered because there was a decade's worth of deposits built up in the neglected combustion chamber and fuel system that the PEA chewed through and spat out.
With MMO I have a definite application in mind for it (actually two: one as an oil additive for the last 500 miles of my next two OCIs, to combat sludge build up; the second as a piston soak to try and free up sticky piston rings that another member here has detailed well). While there are other methods to achieve the same goals, this is the product that I believe can do both in a manner that appeals to me the most.
MMO won't be used by itself in the first application above. It'll be used in conjunction with a high quality, high detergency oil as an additive for the last 500 miles before the short 3k OCI is over and its all drained out. Probably I could achieve the same results, in that particular application, with just the same engine oil I intend to use and the same short OCIs. I'm adding MMO because I think it can help speed the process along a bit, and still do it safely.
I might feel different if the car had the same mileage on it and I was the only owner and person who had maintained it. But I wasn't, it came with a few kinks, and I think MMO is useful for eliminating some of them. Its relatively cheap, safe, and worth a shot IMHO.
-Spyder
eyedrops? contacts?
Hearing about that for the first time are you? Its all the rage today among a sector of the upcoming generation. Some also soak tampons in vodka, then insert into the appropriate opening (depending on the gender, and the opening isn't their mouths). This is particulary common among teenage girls, but also some of the guys.
Times have certainly changed a lot from when I was kid and the "in" thing was getting smashed on a case of beer you went on in with a buddy or two.
Meantime us geezers fret over damaging our delicate engines with a couple ounces of MMO
-Spyder
2001 Taurus. 1 previous owner. 28,000mi current (23,000 when purchased by me). The car had all the OC receipts in the glove box. However this was your typical granny car that set most of its life and might have gotten driven 2-3 times a month for 5 miles.
Had a rough idle that started up about 1000mi ago. Have been running 5oz per 17gal tank for the last 5 fill ups. Currently have no MMO in the tank and the rough idle is gone.
Currently running 12oz in the oil which will be changed out in 500mi. After 2 days of running the MMO, the oil turned much darker.
Has anyone ever observed whether MMO makes a better piston soak than LC20?
to sum up what i've read:
-oil quality is good (individually packaged in clean jugs, etc)
-gasoline quality has much room for improvement (dirty tankers, leaking tanks, etc)
-there are no quantifiable results using MMO because no one is really dyno testing before and after
-MMO is not needed in some applications, but is beneficial in others
-thus far i've yet to read about MMO making something worse, but have read many things about MMO making something better
while i have not done a piston soak with LC20, i have done one with MMO and can tell you that so far, it has worked beyond my expectations.
Putting it in diesel is a bit more controversial. And in defense of the makers of MMO, they advertise it as a gas additive and/or oil additive. Last I looked on their web page, there was nothing there about diesel - in which case the product is being used for an application its not recommended for, and when you do that - as with anything else - you take your chances.
So I call foul on that one :p
Originally Posted By: ARB1977
The only thing i dont like about MMO in the oil is what ever you put in it burns off....for me it did.
I find it interesting that sometimes it does for me and sometimes not? Brothers '00 Taurus burned 8oz over 3000 miles(I put 16oz in for the OCI). Also on our '03 Corolla; I added 16oz and after about 2000 miles(mostly highway), the level is the same.
There was a time line where it stopped being recommended for diesel. I'm not sure what evolution occurred in terms of diesel fuel requirements.
So, it's not for diesel's sake that it's been removed, it's for some emissions evolution or fuel requirement for sulfur level ..whatever. Something that required too much tweaking for MMO to do and still be MMO.
I used to use it in my heating oil tank. I'd pour it in before the delivery. Why did I do this? Every burner tech I've ever seen has had the stuff and used it when assembling the burner/strainer/pump. One even asked if he could fill up his oil can when he saw the container.
I'm sure you can over dose it there too and temporarily soot up your heat exchanger.
Originally Posted By: GMorg
I realize that the following link relates to diesel instead of gas. It has circulated on this site for several years now. I know that there are not enough measurements to provide statistical support of a conclusion, but it does provide an opportunity to "read about MMO making something worse."
https://bobistheoilguy.com/forums/posts/1784831/
the fact that it is for diesels completely voids our arguement here. MMO doesnt even meet the 2007 ULSD requirement so already you're using a product that is known not to be compatible for certain engines.
so yes, it might make sometihng worse in that scenario, just like using gasoline in a diesel would make it worse too, gasoline runs fine in a gasoline engine, but not in a diesel, oh no! it must be bad stuff then and no one should use it!
we're talking about gasoline engines, which are very different beasts.
MMO is advertised to keep injectors and carbs clean - which we obviously know it does.
if you dont beleive me, get an old carb out of a lawnmower that is gunked up and put some of this stuff in there. not to mention the countless people that have used it and noticed either a performance gain or mileage gain from doing so.
MMO is advertised to keep your crankcase clean - which we obviously know it does also.
what else could make your oil turn dark that quick but crud in your engine that your motor oil obviously isnt getting out?
once again, there are numerous testimonials about MMO making things work better, and very few if any that show it has done any harm or damage.
is it always necessary? no it isnt. does it have its place and use? yes, just like everything else (i wouldnt cook with motor oil and i wouldnt drive with canola oil). 'nuff said.
Originally Posted By: Hemi426
Today's engine oils don't need anything added to their chemistry yet every post has someone adding it to their oil or even their gas.
It's called stealth marketing....what I believe you are seeing here on BITOG is a very well done job of having PR and marketing agents posing as ordinary forum members who likely in fact work for MMO...
They create a "monkey see, monkey do" mentality..thus since you see so many supposed forum members claiming they are using MMO that other monkeys will jump on the band wagon.
Oh, there are surely shills here with "undisclosed" conflicts of interest ..so to speak. No two ways about it. You can usually tell when they drone the same redundant rhetoric and manage to insert it even in threads that they don't have any business mentioning it in.
You've heard of SLAPP? Well, now there's SPAY'C. Strategic Posting Against Your Competition.
Now that's funny! I'm willing to bet Turtle Wax doesn't give a S-------t what goes on here. I wish that was the case with some of the other stealthy companies.
I don't work for MMO or Turtle Wax. I work for the State of Florida. And MMO works for me. I only started using it less than a year ago but it works very well in my truck.
I really think we are seeing members here who are using MMO and just posting there results, there are NO PAID POSTERS like we have seen with other oil additives on this FORUM.
Nobody here has to use MMO, members are reading posts on this Forum and making up there own minds.
Honest testimony speaks volumes, and there are more and more satisfied MMO users posting about their success with the product. I wish I was getting a kick back, I could use the cash, or sell the free product and turn it into cash. :)
