Yes, I have used it in many vechiles. I was a big fan when it first came out. I was also more then a bit upset when they changed it from a true PAO oil to the lousy Group III. I never said that it had lousy UOA or that it has ever caused any damage to an engine due to it being a group III. What I said was that it shears badly over the course of a typical OCI! I also said that you could get Shell Rotella T Synthetic for a lot less and that it was at least as good as Castrol Syntec!!
My family used Castrol oil almost exclusively since the 60's! I gree up with a single brand of oil in the house and that was Castrol! I used GTX for long time! When they released Syntec I hoped right on board. I have even had a cam failure while useing Syntec but I never blamed the oil!I even had a set of lifter on a different vechile go bad but I did not blame the oil! I used Castrol Syntec 5W50 in three different vechiles off and on from 1992 to 1998 in a 1985 Ford Tempo, 1986 Toyota 4Runner and a 1982 Toyota Starlet.
If anyone thinks Castrol 5W50 Syntec is so hot do a UOA of it then run M1 15W50 and do a UOA. See for yourself! I am sure that after 7500 miles the difference will be clear. I do not choose to pay $4.97 for group III oil when I can get PAO group IV M1 for $3.89 a quart!
Their are Syntec listing in the UOA. I belive Dr. T runs this a lot. Their is also a syntec blend 10W30 report. Their are some GC reports as well.
You might also recall that I have 10W30 Syntec Blend in my wifes buick after I repaired the intake. It was on sale so I am trying it out. I have also posted recently that my Dad has 15W40 Syntec blend in the Garden tractor on sale as well. SO any anti castrol ideas can be laid to rest. I tell it like I see it.
If you want to belive that the sun rises and sets with Castrol go a head but UOA do not lie and the 5W50 does not hold up as well as cheaper oils! The ASTM testing done by Amsoil also show Castrol 5W50 to be less then supior!
TSOA always trys to spew his Mobil-1 blows engines garbage every chance he gets but offers no proof! He will not even do a UOA of his precious 5W50 or 5W40 then run M1 15W50 for comparison. That preety much says it all right there! On the other hand I run a plethora of oil! Redline, M1,Amsoil,Castrol, Chevron Supreme......
I challange anyone to prove that M1 15W50 in applications that can use it have been cuased damage from the base stock or any additive in the oil itself!
How do you explain the hundreds of thousands of vechiles running M1 or that have run M1 for hundreds of thousands of miles with no failure! How do you explain all the GM,MB AMG,Dodge..... vechiles that come filled with M1 from the factory not self destructing! How do you explain all of the excellent UOA of M1 in all weights here at bitog?
If anyone wants more UOA of Syntec maybe they should try it and send a sample off for testing. I am after all going to do two UOA of Redline 5W40 primarly to get more UOA of this oil for the board. I had not planed on running Redline at all but decided we needed more UOA of this oil on the site! buster did the same thing! I convinced him to try it and he did. He did it mostly for the board as well because he had not intended on useing Redline.
