What lawsuit? Where was it filed? Was it settled out of court? If not, what was the outcome? I'd like to hear about the results.
Where's the UOA data from the failed bearings, etc?
What other "Rotella shearing issues" are you referring to?
In another post, you answered about the buses also having extended OCIs; is that correct? What data exists to show that other brands (Delo, Delvac, etc) would have not sheared under those same circumstances? What you said was that they shortened the OCIs and then went to T5; is that right? So, how do you know that Delvac or Delo would have not also sheared under those same initial conditions which caused the failure(s)? Were they doing UOAs along the way? How did they end up with so many ruined bus engines? Sounds to me like they were not properly monitoring the UOA data. I'm wondering if these failures were not so much lube related, but a failure to properly monitor extended OCIs?
I cannot give much more detail on the lawsuit, as we signed an NDA. It was settled out of court. They're still a current customer of ours, so you can either believe me or not on the lawsuit.
What data exists the others wouldn't in those same situation? Well, you answered your own question, they were not doing UOA's. They were running a cheap product. My data is the fact I have several fleets on a conventional product that are extending oil drains out. I personally believe they probably would of been okay on Delo, or Castrol conventional product. I think they would of met the same fate on Delvac. There's publicly made information that Rotella T4 barely passes the DD13 scuff test. They just meet 31 hours, let alone other tests as mentioned previously.
Those are bearings from one of the nine engines they lost. They did not have a pre-failure UOA and a post failure UOA doesn't... really show much.
This is my own UOA - as I don't feel comfortable sharing customer's data without their written permission. You're welcome to come see it at my office. And talk to my lead chemist / engineer on our technical team about this.
This is a tank wagon (bulk oil delivery truck.) Went 6 months without an oil change. (We normally do every 10 weeks.) Unit was down for tank work between 1/2017 and 10/2017.
Our fleet averages right around 20mph. City driving, delivery time, pump time. So this is approximately, 1000-1150 hours on the oil. As far as we know, it had 3 gallons of top off oil. No major viscosity loss. No major contamination, after that period hours on the unit. (I can go back and look at our telematics if you want an exact amount of engine hours in that time frame. And yes, someone lost their job over it.)
What Rotella marketing claims are specifically "misleading"? If it's clear to you, then by all means, expressly describe it, please. Provide the links to the marketing, and show what it is you find to be misleading. And, then show me how that contrasts to the other brands; which I presume you imply that they are are not misleading. What I'm asking for is for you to be specific about the misleading claims you believe to be falsely represented by Rotella.
https://rotella.shell.com/en_us/pro...e718cd0fc768d05faab7059e52f0938/t4-15w-40.pdf
So I'll just link their own marketing page.
1. Enhanced wear protection compared to....? They say prior Rotella 15w40... but what version? Which Rotella Triple protection formulation? It has changed several times over the years.
2. Protects 50% longer than previous rotella's against oxidation? Well, how long did the previous generation last?
3. Wear protection beyond CK4 standards... Okay... on what test?
4. The DD15 images they show... They don't mention the drain interval amounts at all. They also don't mention of it was run it's entire life with Rotella or not.
5. Keeping DPF filters 'cleaner' - again... compared to what? Some random face plugged one?
Their purse swinging against Mobil was even shot down by detroit: https://jobbersworld.com/2018/06/25...s-claims-and-elm-announces-no-price-increase/
In comparison to:
https://www.docs.citgo.com/msds_pi/C10166.pdf
Pretty simple. Shows the comparable test results. Doesn't make any outlandish claims.
https://cglapps.chevron.com/sdspds/PDSDetailPage.aspx?docDataId=481951&docFormat=PDF
Same, pretty simple. They make some claims, but put the big * as well, but nothing as outrageous.
If I call "what" market priced? I never gave a dollar value for anything. What I said is that, ignoring regional sales pushes, Rotella falls inline with the other major brands in long term pricing strategy. In any given month, Rotella, Delo, Delvac, VPB, etc all have sales pushes that end up making one brand less expensive than another. What I was referencing is that the major HDEO makers typically compete in the same markets, and so they cannot afford to be unaffordable for long, lest they lose market share.
I see Oil prices differently than most. Market pricing for Rotalla T4 is normally between $14-17 bulk. National account pricing is real screwy, I've seen Rotella being delivered, significantly below distributor cost, to national accounts. So if a national account can get it for say, sub $9/gallon. Why is it worth $17 to a normal fleet? When you can get at least, a comparable product for $3-5/gallon less? When you can get a statistically better product, for the same amount, or less money? (Especially if you go up to a syn blend?)
Rotella keeps up market share, because they spend over $50 million annually on marketing. Part of this is literally just buying gallons, with the above fleets.
Employees change jobs due to all manner of reasons. That's not the inference I took from your initial complaint in your previous post. How does SOPUS employee retention relate to consumer loyalty at the shelf at Walmart??? You've lost me here.
It's a pretty big deal when you go through several General manager / Vice Presidents of Lubricants in so few years. One, lead a complete formulation change (and the naming change up) of Rotella in ~2008. Those positions dictate formulations, pricing, etc. So it's a really, really big deal when that position rolls over, especially as fast as it has in Shell. Again, not something the consumer really sees, but something I see. And then the fall out of that position being changed over.
You may have the proof, but you haven't posted it here for us to see; you've not backed up your claims. It's easy to stand behind anonymity and make bold claims. I understand that perhaps you don't have the ability to reveal where you work; no one wants you to risk losing employment. But without the data to back you up, it's just hearsay at this point.
Can you share that data? And more importantly, does it show correlation to your claims regarding the claim of Rotella shearing and the failures you reference above?
Not quite UOA's but here's some test data against T5. And you can scale it to T4.
P66 named names in their tests.
If I come off "tainted" then I haven't done a good job communicating my interests. I value data-driven investigations and decisions. When people make claims, I want to see the basis for the position. Often things are anecdotal; a sample size of one or a few. That's not enough to convince me of large scale concerns regarding oil shearing, as you imply.
I think what I object to regarding your position is that you made a lot of large, sweeping accusations with no data presented to back up your claims. That's typical of the internet conversations, for sure. I don't think anyone has any "dismay" about your love or hate for SOPUS; I doubt anyone here is that deeply vested into your opinion as to be dismayed. It's not that your opinions are invalid; it's just that they're unproven to us here at BITOG. What your family does really doesn't interest.
Help me, and others, understand these bus failures; tell us the specifics about the lawsuit and evidence presented therein, relative to Rotella and it's "shearing" and "misleading marketing".
I'm not trying to taunt or troll you; I apologize if it comes off that way. What I want to see is the real data to backup your claims.
That's the data I can share, off the top of my head without digging through more files and scanning them in.
And, to me, you're certainly trying to troll me. Again, my opinion.
