As in?Anyone else notice a consistent pattern with these type conversations?
Outside of having access to a large set of data from controlled studies, this is just water cooler conversation.Emotions
Question gets asked, lots of anecdotal info and a bit of data from very narrow sample pools, and we all eventually realize we don't know much of anything, and learned nothing new. We continue to make decisions based on our hunches.As in?
Litterally this forum in a nutshell.Question gets asked, lots of anecdotal info and a bit of data from very narrow sample pools, and we all eventually realize we don't know much of anything, and learned nothing new. We continue to make decisions based on our hunches.![]()
He's a mechanic.Have you ever heard of a hobby? It's a hobby, guy. My question is, why are you so insecure about your own practices that you feel the need to convince someone else that they need to be insecure about theirs? You're going a little hard on this, don't you think?
You sir, are a dying breed….or a suckerThe third option and maybe I'm a sucker for feeling this way is when someone buys a vehicle from me, while I offer no warranty, I do try and sell that person a vehicle that was well-maintained, even if that means I spent a couple of hundred dollars more on oil changes over my period of ownership.
Go take a ride in one of your VW's. It will calm you down.LOLReading this and thinking of driving a '99 Corolla in this way makes me want to hang myself.
Let me add that if you are in a metropolitan area, your driving is "severe use". Country, rural, or interstate driving is not. So change your oil accordingly.You sir, are a dying breed….or a sucker
Most people (and it’s getting worse) will tape a nickel to the car in the hopes that it makes it down the street before engine fails.
A few of you have said it already, but the owners manual OCI/maintenance items are to get you through the warranty period. After that, they could care less. YMMV.
Yes and at the watercooler emotions wouldn't get so high.Outside of having access to a large set of data from controlled studies, this is just water cooler conversation.
Then again, that also describes 95% of the content on this site.
And for every one of these junk boxes…er…Jettas there’s one that had oil consumption issues.And for every one of these appliances...er...Camrys there's one that went longer without any oil consumption issues on long 10K runs...your average person probably forgets to change it once in a while too...opppsies! 10K with a v. high quality oil (I'd say the oil is more than likely the culprit) for the the highway commuting the video talks about seems v. reasonable to me. Did that in my MK4 Jetta with Mobil 1 0W40 10K changes for a big chunk of the 220K highway commuting miles it had when I sold it without any oil consumption issues.
Although it has chilled compared to the past - peopleLitterally this forum in a nutshell.
I live 3 miles from a mountain that has a beautiful view of the Boston skyline 50 miles away but where I live is very much rural. My commute is 8 miles, averages 40mph, and only has 3 stops. Nice, constant, and easy cruising and RPMs rarely go over 2K. To put into perspective I was tracking my engine and transmission temps and engine temp is up to full operative temp within 3 miles but even on +90F days the transmission never gets above 170F. Fully warmed up it sits around 200F.Let me add that if you are in a metropolitan area, your driving is "severe use". Country, rural, or interstate driving is not. So change your oil accordingly.
I've written about that in a few previous exchanges:He talks about using a high quality synthetic vs a lower quality one. But the experts on here say that if it's API certified then it's fine. So which is it? Can't have both ways. No decent independent mechanic will recommend 10k oil changes anyway. What are the low quality synthetics on the market?
In reality, using an approved oil at OEM intervals will probably get you to their target service life....which is around 150K. But along the way, you may get some oil consumption and your engine may not be remain as clean as some desire. But for 95% of the public, that is good enough.I've written about that in a few previous exchanges:
https://bobistheoilguy.com/forums/threads/high-performance-lubricants-oil.356032/page-3#post-6145451
https://bobistheoilguy.com/forums/t...e-protection-as-synthetic.354599/post-6110052
The API approvals dictate a minimum level of performance. That does not mean that some oils aren't going to perform significantly better than that. Mobil for example, limits the oxidation to a fraction of what's allowable by the API.
Absolutely, and that's really where the basic API approvals likely aim to get you.In reality, using an approved oil at OEM intervals will probably get you to their target service life....which is around 150K. But along the way, you may get some oil consumption and your engine may not be remain as clean as some desire. But for 95% of the public, that is good enough.
I wasn't even referring to boutiques, just oils like M1 vs Supertech for example. Even in the mainstream, there can be significant differences in performance of the finished product depending on the internal targets set by the blender. When I was talking to Dave at @High Performance Lubricants about some of this, he remarked that they internally tested/benchmarked Mobil 1FS 0W-40 and he was blown away by how good it was, let alone at the price point Mobil sells it.Then you have those who want "more," which would be some people on this forum. People who "wish" their engines will last 300K with internals that are clean enough to eat off of. Basically the corner cases. And that is probably where the boutique oils come in; people are willing to pay 2-3x the cost of an approved oil in hopes of making their engine last longer and run better than intended.![]()
I just maintain my vehicles because I never know when I'm going to get rid of it and don't want it to break down on me while I own it. Last car I spent several thousand fixing it so that it was fine and then dumped it a year later.The third option and maybe I'm a sucker for feeling this way is when someone buys a vehicle from me, while I offer no warranty, I do try and sell that person a vehicle that was well-maintained, even if that means I spent a couple of hundred dollars more on oil changes over my period of ownership.
You don't need to hang yourself, just get rid of the '99 Corolla although you could wait 6 months to a year to see if used car prices come down more.Reading this and thinking of driving a '99 Corolla in this way makes me want to hang myself.
