NYH
I couldn't afford any trucks with the 7.3L. I was looking for entry level GMC/Chevy and Ford models. Wanted to try something different then my usual Ram's. The GMC/Chevy guy wouldn't work with me at all. Tried low balling on my trade, wouldn't come off the sticker price and wouldn't return phone calls. I went and checked the F-250 out and like it. Plus, it has way more equipment that I'll use, then the GM's had.I wouldn't mind the 6.8 super duty but I dislike that you can't even option the 10r140 with it and have to get the 7.3 or 6.7 to get it. I'd get the 7.3 gas not for the power but for the beefier trans. As for oil I'm not running 5w30 in either of my 5w30 calling OHV v8's. I'm using 15w40 and they're much happier with it. Dead silent valvetrain at hot idle after running for hours in this heat. I'm also using 5w-40 instead of 0w-20 in my new one and it too quieted down to where I can hear the pump unlike before which was a valvetrain clatter fest in comparison. A whole lot quieter and healthier sounding.
But if you really want to stick with 5w30 and it must be m1 for whatever reason I'd use Mobil 1 Extended Performance and run it for two intervals which would probably be 10-13k and not worry about it since it's an NA non direct injected ohv engine with a big sump and it not being turbo or direct injected means it's soft on oil.
NYH.
