Oil won't help the water pump live longer.I ask because I have a Ford vehicle with the dreaded 3.5 Duratec V6 water pump. I know some may think this is splitting hairs but in my case I beg to differ. Since I got it at just 2,000 miles, I drained the Motorcraft blend at 4,500 miles and put in Supertech Advanced Full Synthetic and was intending to change it every 7,000 miles but have moved down to 6,000.
Thing is, the higher the mileage goes on the car, the more anxious I get about the water pump failing. I'm at 11,800 miles now and I am deciding to go with the best full synthetic here on out there to do everything I can to help the water pump, not just Supertech. Yes, I am also flushing the coolant, I am about to do my first flush and will then do the flush annually for the rest of the car's life.
My understanding is that Mobile One Advanced Full Synthetic is generally considered the best available oil. How true is this? What other oils are better, and by how much and how much do they cost?
As mentioned above, replace the water pump early, on a schedule, to avoid the milkshake.
Or, since you're apparently super worried about it at under 20,000 miles, trade it.
